Tidal app review
22K views 50 replies 21 participants last post by  RoryGardner
I finally got around to getting a Tidal account to try it out. Here's my assessment of it and how it is in AAOS.
1. Tidal music selection:
So, upon signing up, I was impressed with how it made some EXCELLENT artist recommendations as I picked from the artists they had within different genres. There were some I had completely forgotten about from 20+ years ago. Sadly, that didn't seem to translate into the "Welcome" playlist or the personalized playlists it later made. The "Welcome" playlist was almost exclusively 90s/00s alternative. That's not a bad thing, as far as music, but it was probably 1/3rd of the artists I had picked, with others being hip-hop, rap, EDM (old and new), classical, etc. And then once it populated some personalized playlists, 7 out of 8 of those were dance/EDM. So....I'm a little confused with how it's algorithm is coming up with playlists.
2. Album and playlist transfers:
Transferring over my playlists and favorited albums from Spotify was super easy with Tune My Music. Of the music I had on Spotify, most was found over on Tidal as well, with a notable exception of a few soundtrack albums and playlists comprised of older 2000-2005 era downtempo electronica.
3. The AAOS app:
It's similar in functionality to Spotify, which is a good thing if you're used to one or the other. I'm a little bit bummed that the "Master" level streaming is unavailable through the AAOS app, when it is available otherwise on the mobile app. It wasn't available regardless of cell signal connection, or if connected to WiFi. (more on compression below)
It does not automatically restart when re-entering the car if it's been more than a minute or two. Tidal doesn't seem to cache any of it's music locally, like Spotify does. So Spotify wins in that regard.
4. Sound quality:
Is the sound, when set to HiFi, that much better than Spotify set to High? Eh...maybe. It's definitely of a very high resolution and quality, for sure. But is it like what you notice when going from SiriusXM to Spotify, for example? Not at all. That's probably a function of starting to reach the practical limits of the speaker system in the car, the car environment, and the human ear's ability to really notice a meaningful difference at a certain point.
For refence, sound settings are shown below, with surround sound off, and with the focus on the driver's seat.
Overall, do I like it? Sure. Is it comparable to Spotify in terms of music availability? Yes, give or take a little. Would I get it strictly because of the higher bitrate? Not necessarily, and certainly not if there was a real price differential.
#18 ·
I had the same issue/experience previously, however my assistant has started to play music via tidal as of a few days ago. It seemed to coincide with an update in my vehicle of Google assistant in AAOS.
(As I think of it now, I've been doing this with the tidal app as the active audio app. Not sure I've tried it with there first being another audio app active... If that makes sense)
#6 ·
I found that a good recording translates to BT. You can and I have built a high end car system around BT. I forgot the tidal terms. Hifi is lossless and masters is their MQA. Tidal has a lower tier below Hifi.
The bit rate matters but I found 320bps music a bit sloppy with bass notes.
If you have a high resolution track over BT it doesn’t seem to lose as much.
#8 ·
HiFi = 1411kbps (aka: CD quality)
Master = 9216kbps
Of the different codecs available for Bluetooth 5.2, LDAC supports the highest bit rate at 990kbps. Everything else is below that, some might have higher resolution (LDAC is 16-bit). The worst is probably anyone using an Apple product to stream to AAOS, since AAC (Apple's codec) is limited to 320kbps. They make up with that by retaining 24-bit resolution and some fancy processing IF the receiving audio piece (headphones, speaker, car) is also an Apple product. If it's not, like the Polestar, then the resulting quality is 16-bit equivalent.
#12 ·
I will say that I switched to Tidal and went through the exact same process as you. I don't have my EQ settings off-hand but I think they're pretty similar to @stevelup and his "HK Reference".
My experience was pretty similar. I'd say greater than 99% of my music from Spotify and YouTube Music (I did both) were matched successfully. The only thing that threw me a bit was the "Liked" songs getting dumped into "Tracks" instead of a different playlist, but that was OK and I've gotten used to it now.
As far as the sound quality, my experience so far has been awesome. The Tidal streaming in HiFi mode has been far better than Spotify for the same tracks. I listen to a pretty wide range of stuff and two tracks in particular stood out for me in comparison; Time by Hans Zimmer (from Inception) and The Mugician by Keyon Harrold. Both pretty different tracks but so much better between the two services. Time in particular I could hear more orchestral back-end stuff like people moving and so on... much clearer and less muddy. Having watched Keyon perform The Mugician live a couple of times, the quality of the Tidal version of his song got me much closer to that in-person experience. Again, I could hear the occasional click of valves on his trumpet and there was a richness in the bass that is just missing from the Spotify version of the same song. And yes, I have high quality streaming turned on in Spotify already.
I haven't noted any problems with no caching of the music yet so it remains to be seen how that pans out. But generally I'm really happy with this switch to Tidal.
Am I ready to dump Spotify? Yeah, pretty much. Even long before the current tempest in a teacup with Joe Rogan I was already considering a move away from Spotify because of the way it treats artists and the crappy sound quality. This recent thing just reminded me I needed to try out Tidal and this so far has been a great experience.
I do note that so far the Tidal app seems to lack the ability to create a generated playlist from a currently playing song. I used that feature a lot to discover new music so if anyone knows how to do it in the AAOS app please let me know?
#19 ·
Tidal is the best sounding streaming app I have ever used in the PS2. I was disappointed with the sound system with Spotify and went to Tidal in the car. I do pay for the Hifi. I think this is a huge difference maker. The bass is rich and not a thud. The voices are so clear.
#20 ·
Tidal is excellent and I used it for 5+ years until I switched to Apple Music last summer when it started lossless. I just prefer it more than Tidal for less money.
#23 ·
That's a different system in a different car... The fact that they both have a nine band eq is where the similarities end!
Honestly, my car sounds utterly horrific with your settings - as would most others. You and a small number of other people have an issue where there's a massive lack of low frequency energy, and your settings are compensating for that.
I promise you, I'm not making this up, your settings genuinely are totally unusable in my car, and it very much sounds like mine are unusable in yours. So there's clearly some inconsistency there - either hardware or software.
#24 ·
I wasn't saying they were the same car, simply that your settings go against general convention AND against what has been used in a 'similar' system (including the HK system), and what's used by XC40 owners. These are all HK developed systems for Volvo based cars, using the same suppliers. It would be odd to have the results be this drastically different.
And again, sitting in my other car with that similar system, from within the HK family, and recreating as similar a listening experience as the P2 system can support...the result is the settings I have.
I don't deny you, or others, are experiencing what you are. But I'd chalk that up to a potential hardware or software issue, which isn't really that far out of the realm of possibility with Polestar, is it?
Or again, maybe it's that you like more of a "pop" or vocal forward sound. 😝
#26 ·
Which in my opinion indicates something is not quite right in your car. The neutral (flat) setting should be fine, especially with the Dirac tune. The other settings are for taste. If it needs such extremes than I think either taste is extreme (doesn't sound like it is) or something is not quite right with the car. I couldn't listen to it with sub and bass and low frequencies up to such an extreme.
Granted it is hard for me to change between systems, especially as my daughter makes is a dj/producer and masters to neutral, but bass to such an extreme would be unlistenable with a good master.
#27 · (Edited)
I also suspect there might be difference in the eq reponse depending on which «sound experience» is selected. In my car I would guess +/- ~3db at each band is the most I can get. I would like to have an old fasion fader instead of the «sound experience» setting. (Also 3’rd party plugins like BBE or similar might perhaps help getting better sound on low volume).
I use Spotify, Tidal and AudioWagon and think the sound quality is plenty good enough for listening in a car, but Premium? - No.
#28 · (Edited)
Actually - I am not sure that the "Tone and equalizer" works at all in my car. Extremely little response and I am not able to detect the difference when the tone and equalizer setting is changed. Perhaps Spotify - that I tested this with today - is bypassing the "Tone and equalizer" processing stage?
It sounds like the setting is neutral (flat) no matter what I do.
Lucky for me that setting sounds just fine I might add. :p
Edit:
Have just retested using AudioWagon and a known good sounding track. Sub., Bass and Treble sliders responds as expected but the EQ. section does not respond.
#30 ·
I have tried the reset and that didnˋt change anything. As I regulary use professional sound equipment such as digital mixing consoles I was expecting similar real-time response in the car. I was kind of hoping that there is something dead simple I have missed since the EQ does not respond.
#31 ·
The EQ is powerful and responds instantly, so you've got a problem.
Maybe try an infotainment reset? Press and hold the home button at the bottom of the tablet until the screen goes completely blank (hold it beyond the 'screen cleaning' mode).
#32 · (Edited)
Have tried infotainment reset (not because of this issue though), so if the EQ is supposed to be very responsive there is something wrong for sure.
Has anybody seen a block diagram showing the HK sound system and the connection to the infotainment?
For example, the following would be interresting to know:
Is the DAC located in the HK-part?
Are the EQ and Surround processing utilized as SW plugins in the infotainment or are they implemented as firmware in the HK system?
Is there any difference in the 2021 vs 2022 issues of the car?
#33 ·
Great review!
I’ve just been trying Tidal which I like very much on other devices. The fact it doesn’t resume is frustrating to the point I find it nearly unusable. Is Spotify doing that? I wasn’t clear from your description? I won’t be using Spotify but I was trying to understand if it’s a general restriction. It’s fine on YouTube Music of course.
#49 ·
No complaints using Lossless Apple Music by BT to the car. It's clear enough for car applications.
And YES, I can tell the difference if I streamed the same tracks in lower resolutions.
