tldr; I didn't notice any magical range improvement on a 60 mile drive
Well, I just did my normal drive to the weekend place last night and then charged up overnight to see the usage. I had some unexpected results that will need more results to verify.
Normal trip is 33 to 34% battery starting at 90% and the car charges between 25.6 and 26.8 kWh overnight once I get there. The distance is 60 miles. Cabin AC on at 68 F. No heated seats or steering wheel. 2 passengers with trunk fully loaded (only an extra 100lbs though). City streets @ 35mph 1/3 , rural @ 45 mph 1/3, highway @75 to 80mph 1/3. Temp 51 F at start and 48 F at the end of the trip.
Last night, I used 34% battery according to the car, but then the car charged 27.84kWh overnight. Trying to determine the battery size from this I used a simplistic equation .34 * X = 27.84 which is simplified to 27.84/.34 according to my 7th grader. This gets a result of 81.9 kWh battery, which can't be right.
All of my previous calculations from other trips the battery size came in around 75kWh, which is what I would expect. So this was a bit unexpected and maybe something changed with the update. Of course one datapoint isn't all that useful so need to see if a trend develops.
So I certainly didn't notice any additional range, and used slightly more juice than normal, but did have to swap the car once with the wife's car earlier in the day so used a little battery moving it.
