1 - 11 of 11 Posts
2019 Volvo S60 T8
Has anyone that's taken delivery of a P*2 experienced towing something more than a bike rack or utility cart? How was the driving experience and range impact?
2019 Volvo S60 T8
I think you're gonna want to load the trailer with batteries. :)
Exactly why I'm asking about other people and not sharing my story! (Assuming I actually had my P*2 already...)
Reactions: JPC
Honestly following people in Tesla's towing stuff ... Drag Efficiency is more important than weight. Therefore if you are pulling a small trailer that's no taller than the rear of the car ... I can't see much difference. I'm going to try next summer to take my 3 Bikes on the back of a trailer around 300miles. This will show me any major loses. But until then I can only go by what I've read/watched regarding other EV's.
So towing a horse box would be bad or anything with a flat front, but I assume you are asking about something more like this:-
2187
Which would be fine and may at most cut 25% range at worst.
Reactions: gtpolestar
2019 Volvo S60 T8
Thanks, @GDank. That matches my vague understanding as well - if the trailer is small enough to slipstream behind the vehicle, then the aerodynamics are pretty straightforward. Also if the car is powerful enough (I think the P*2 is fine there! :)), then the cost of the additional weight is not as taxing as it would be for a small 4-cylinder car for example.
Do you have any resources you've seen on the Tesla side? I have only seen anecdotal tests and not systematic metrics. From what I've read, I think ~20-25% seems reasonable, but I was hoping to hear some real numbers from P*2 owners.
I've been looking into this as well. I would expect a significant hit on range which might make the whole business impractical. I agree with GDank that it's all about drag.
A few that could work decently would be the following:
Timberland Pika
Midwest Rover
The Polydrop
The Meaner Bean
The Tag Teardrop
The Terradrop
And, maybe, just maybe, the Safari Condo Alto R1723.
2188
2019 Volvo S60 T8
Timberland Pika
Midwest Rover
The Polydrop
The Meaner Bean
The Tag Teardrop
The Terradrop
Given that the P*2 is shorter than the average CUV, I would expect the drag to be slightly worse than I see in beautiful images like this! 😝
Tesla Model 3 is probably a better example, although it's aerodynamics seem more slippery than the P*2, so maybe the higher drag coefficient of the P*2 would actually have a benefit of creating a higher wake. It's been years since I assumed any knowledge of fluid dynamics, so maybe I'm just being an optimistic (future) owner!
The slightly larger frontal area and higher drag coefficient means that there's a larger wake/vortex/low pressure zone behind, so that the Polestar 2 should be a bit less affected by trailer drag than a Tesla with the same trailer.
I've time stamped to the part that matters. This is a Model X towing two caravan's. One they get 1/2 range the other 3/4 range.
I'm sure the Polestar 2 won't notice a small trailer or bike rack. Unfortunately with a mix of lockdown(s), low ownership numbers, a newly released car, etc... there are not enough towers around here, and none that have gone any considerable distance to give numbers that would be realistic on a long dive.
If I'm bored one weekend before xmas I'll load my 3 bikes up and do a test up the motorway and back down again. But I'll have to be that bored and know there is really cheap electricity that night!
2019 Volvo S60 T8
Great video link, thanks!
An interesting (and only tangentially related) piece of information regarding drag on tandem objects: When you draft behind someone on a bike (or car) both the drafter and the lead bike/car gain an aerodynamic advantage. So towing a trailer could hypothetically reduce the drag on the car itself. But the overall drag still goes up of course.
Ok I’m done...
1 - 11 of 11 Posts
