1 - 20 of 22 Posts
· Registered
Has anyone tried to take the star off the trunk and hood? Is it glued on?
I usually take all names and badges off my vehicles with a little heat and floss.
· Registered
2022 P2 Midnight PPP
To each their own, but to me it would look like a vehicle used in a commercial or TV show that didn't have permission of an automotive company. I like the stealthy subtle branding of the P2, but getting rid of everything feels a bit much for me.
· Registered
Black PS2 SRSM
I had the front badge removed for ppf application.
It is glued on with 0.8mm double sided tape.
It was removed using braid fishing line.
Under the front emblem there are 4 locating holes in the plastic, two round, two oval.
I filled the holes in and put some clear vinyl wrap over them to see what it would look like.
Frankly, too me, it looked like sh!t.
The indentations around the holes were still visible.
PPF went on and badge was replaced.
· Registered
Not 100% sure but emblems are typically taped/adhesive taped on. Usually can be warmed with a hair dryer and then use dental floss behind the emblem to disengage.
here is a replacement….https://www.vivaperformance.com/genuine-polestar-rear-emblem-polestar-2/
i don’t have a problem with the rear emblem but didn’t like the side stickers. Good luck.
· Registered
Same here, and I agree it looked very weird and bad.
· Registered
Discussion Starter · #11 ·
Thanks for the info - I don't like the stickers on the side either, so I'll remove them.
I'm getting the entire car covered in PPF.
· Registered
Discussion Starter · #15 ·
Are you doing that for a colour change through the PPF material like a satin or matte effect? I mean otherwise there isn't much point in covering the entirety of the car.
There is a point to me! My last car was black, and I had the PPF on the front end, mirrors etc., and the rest of the car was Ceramic-coated. After a few years of washing and dusting, the unprotected areas had hairline scratches and swirls, and the PPF area was pristine.
By covering all painted surfaces, there will be no hairline scratches or swirls and I don't have to wax, and the cost is the same as 1/2 PPF and the other half Ceramic.
Makes total sense to me.
· Registered
Launch Edition since Oct 20. 25k miles driven.
Like many people, I removed the side stickers as soon as I got the car. I would’ve loved to ditch the front & rear emblems if they were just adhered, but filling holes & respraying was too much effort for me.
Sleeve Automotive exterior Bracket Fashion accessory Metal
I look forward to seeing the results if you go for it though!
A thread from back when the car was pretty rare…
· Registered
I'd be looking into your washing techniques or what else happens. Getting hairline scratches and swirls when ceramic coated is not normal. But hey if it works for you then go for it.
· Registered
Discussion Starter · #18 ·
Thanks Dave for the info and link to the other thread. Considering there are registration holes, I will leave them on.
Maybe my PPF guy will remove them and then reapply when complete. I will however remove the stickers from the front fenders.
1 - 20 of 22 Posts
