Just now and it's working again!
This is great news. Just updated to 2.2 and have along drive tomorrow. Will be nice to have AudioWagon back.Just now and it's working again!
I ignored the message that popped up when I first connected the USB drive warning that it wasn't readable, opened Audiowagon and it worked. Had forgotten how much better it sounds.
Hi I am as well in Canada , when will be the 2.2 update available here in Canada . I don’t even have 2.1 yetI just saw the release notes, amazing work MoleMan.
Thank you very much.
Smart move , at 2.2 AudioWagon will work againI'm still on P1.9
I declined versions to keep using AudioWagon 😄
That is possible, I implemented a draft version of this behaviour while USB was blocked so I could still listen to music 😅. I did not release it because it still had lots of bugs, you needed to set up your own server etc. was not that easy to use. And now that USB is re-enabled I don't really see the need to have such a feature.is there a possibility to copy music files to the onboard diskdrive/memory as there is storage space dedicated to music files?
I don’t like the usb stick poking out ready to be bumped and break into two piecesAnd now that USB is re-enabled I don't really see the need to have such a feature.
Being able to copy across from the USB to internal storage and then play music without a USB stick always plugged in would be a neat feature.And now that USB is re-enabled I don't really see the need to have such a feature.
