Just popped out to charge car plugged in and charger kept disconnecting. Thought was charger fault tried to get back in car key fob won’t work used emergency key result alarm and horn goes off unable to switch off. Now awaiting recovery !!!!
Does the alarm have its own battery?Sounds like a dead 12V battery. 😕
I doubt it ... there is always a failure rate on things like batteries.Vin 17*** so poss still an issue
Alarm activating when using physical key is pretty standard, have you tried placing the key in the designated area in the armrest to see if the car starts?Just popped out to charge car plugged in and charger kept disconnecting. Thought was charger fault tried to get back in car key fob won’t work used emergency key result alarm and horn goes off unable to switch off. Now awaiting recovery !!!!
Ok let me slightly change my wording .... an "ALMOST" dead battery.Does the alarm have its own battery?
Well someone did tamper with the car, as the key was used without disarming the alarm!Ok let me slightly change my wording .... an "ALMOST" dead battery.
Normally when battiers are about to die you will get the alarm going off, as it thinks someone is trying to tamper with the car.
Ok not what I meant ... when the battery is low on many cars ... and Alarm isn't getting a proper supply of current, it thinks someone is trying to Disconnect the Battery but doing a bad job if it. So the Alarm goes off, hence why I think it's the 12V battery issue, firstly the central locking isn't working, and then the alarm / horn (another common symptom).Well someone did tamper with the car, as the key was used without disarming the alarm!
I get this all the time with my Audi when I use the plastic activity key, starting the engine with an immobiliser registered key (such as the plastic activity key itself) stops the alarm.
My time watching Lock Stock has served me well.Pete Tong.
Yes, LTE is 4g. This is one of the changes in the update, it's 100% a visual change.Update. Got my car back in less than 24 hours. Volvo service said they have updated the software and all is well. No faults were found and no 12v battery issue. Hmm. But now have no 4G just LTE. Call to CS said this is what will now show after the latest software update !!!. But they are going to confirm and get back to me in the next day or so.
