Hello, i am on testtrack 4. Is there a plan to Update to Version 24?
Vehicle setup doesn’t allow selecting Plus package for MY21 launch edition? Not sure if it has any meaning for the app functionality. 🤔 I’ll take the feature is still being developed. No need to reply as you’re busy with the app and life 😬This feature is currently still under development and needs some more testing and fine tuning. I can't say yet when I will release the next update since I have some more points on my agenda I want to tick off before then.
Here are the current changes, some of which are not quite finished yet:
But you can expect the update sooner rather than later![]()
I didn't go that far, but I do have a PHP script that can receive and decode the JSON and write it into a MySQL-DB. PM me, if you are interested.Has anyone created a solution to get the SOC level into Home Assistant using the new Webhook function?
Actually yes, this is indeed the intended purpose for now 😂 But that's a debugging leftover when I needed to crash the app intentionally to test some behaviour.Hi. N00b question here - what is the rocketship logo in the top right corner for? Pressing it makes the app crash for me (I'm assuming that's not its purpose!)
As far as I am aware the Launch Edition did not have a heat pump. So it does not really matter anyways. As it is now the app only uses the settings which influence the power to scale the gages on the main view. All other settings are not used yet.Vehicle setup doesn’t allow selecting Plus package for MY21 launch edition? Not sure if it has any meaning for the app functionality. 🤔 I’ll take the feature is still being developed. No need to reply as you’re busy with the app and life 😬
I have informed all track maintainers about the release. If and when they release the update is up to them.Hello, i am on testtrack 4. Is there a plan to Update to Version 24?
Android requires the protocol to be https. Nothing I can change.What am I missing here?
Maybe the setting could be named “heat pump” as the launch edition cars had the same options pilot/plus/performance but heat pump was not available.As far as I am aware the Launch Edition did not have a heat pump. So it does not really matter anyways. As it is now the app only uses the settings which influence the power to scale the gages on the main view. All other settings are not used yet.
I did create a solution using the webhook function, but it requires a https connection to your HA system.Has anyone created a solution to get the SOC level into Home Assistant using the new Webhook function?
The Launch Edition did not have any packages, it was just the "Launch Edition", so I do not see anything wrong in the current implementation. Also , this setting does not affect anything besides the visual apperace of the bar graphs.Maybe the setting could be named “heat pump” as the launch edition cars had the same options pilot/plus/performance but heat pump was not available.
It’s all good. I guess launch edition in Germany was different from USA. But I have LE and got to choose which packages to get. From my car specifications …The Launch Edition did not have any packages, it was just the "Launch Edition", so I do not see anything wrong in the current implementation. Also , this setting does not affect anything besides the visual apperace of the bar graphs.![]()
If you want to contribute with a Finnish translation, please create an issue at Issues · Ixam97/CarStatsViewer and someone will assist setting you up with the translation tool (Lokalise).Great project and big thumbs up for the hard work! Would really appreciate to have opportunity to test this and also could contribute with Finnish language version.
