2022 Polestar 2 Dual Motor, Snow, Pilot and Plus Packs
First Rivian sighting in the wild! I LOVE the blue color. My P2 looks so small next to it 😂
It’s probably due to the corner location enhances the aero of the box design…..Pretty interesting corner location for the charging port on the Rivian … one must wonder why, eh? Did they do some depth analysis which part of a car gets involved in a crash the least? … and left corner came up. It definitely makes a sense as you eliminate left hand turn T bone impacts, but that cannot be the only reason, can it?
I was being sarcastic which doesn’t really go over well on a forum lol. If the P2 has crap aero the Rivian must be even worse.How so? If you put on the side just under the A pillar, let say… it will be completely flat when closed shut. And must be much easier to line up everything properly … hence why most cars have it on a flat part.
Gives the most flexibility when you are towing something.Pretty interesting corner location for the charging port on the Rivian … one must wonder why, eh? Did they do some depth analysis which part of a car gets involved in a crash the least? … and left corner came up. It definitely makes a sense as you eliminate left hand turn T bone impacts, but that cannot be the only reason, can it?
Primarily for towing situations is my guess. Its probably easier to plug in without dropping the trailer.Pretty interesting corner location for the charging port on the Rivian … one must wonder why, eh? Did they do some depth analysis which part of a car gets involved in a crash the least? … and left corner came up. It definitely makes a sense as you eliminate left hand turn T bone impacts, but that cannot be the only reason, can it?
The charging of cars that tow is not compatible in general with the placement of 90% of the chargers I’ve seen. They are all located in dead-end locations which means either you decouple to charge or you block spots for non-EVs (pissing people off) or you block charger spots (pissing off EV owners). It’s a no-win situation, mitigated by the fact that EVs are terrible tow vehicles in most cases. The Rivian is designed to tow, however, so they are going to need to think about charger stall placement above and beyond the actual plug itself.Yeah, assuming it’s not a type of a stall where the charging cable station is right in front, which I see a lot in my neck of woods …. If trailer is left park there, it will block easily the passage behind the standard car size box. But I guess, Rivian is working on their own network, so perhaps there it will make always more sense.
it's to make it easier to charge. The Rivian Adventure Network will have a few stalls designed for those with a trailer so it's easier to pull up to without blocking the way. Depending on which way they pull in, it makes it easier to bring the cable around the front if neededPretty interesting corner location for the charging port on the Rivian … one must wonder why, eh? Did they do some depth analysis which part of a car gets involved in a crash the least? … and left corner came up. It definitely makes a sense as you eliminate left hand turn T bone impacts, but that cannot be the only reason, can it?
LOL not at all. You're so close to the factory, so I can see whyIs it bad that living in St. Louis and traveling through Southern Illinois on the regular I am actually bored of Rivians now? I've literally seen more of them than I've seen Polestar 2's![]()
