Cracked Rim
Tags
rim
14K views 64 replies 19 participants last post by  ArcElectric
I'd still use the sealant. it'll make things messier inside, but it should seal that crack. (In fact, you could probably get away with that fix for a very long time.)
If there's no visible damage to the rim, but a crack in the rim body, you've got a good argument that this is the result of a manufacturer's defect. If the crack was on the edge of the rim, not so much.
