1 - 1 of 1 Posts
12v digital tire inflator with pressure gauge
It's a simply preset air compressor to your target PSI and it will auto shut-off when reaches to avoid over-inflation. Its powerful 140W automobile tire pump delivers inflating air at impressive rate of 30 L/min.
• LCD backlit digital display. Apart from inflating air, the built-in digital air gauge can also check and monitor tire pressure with large bright LCD backlit digital display.
• Four display units: PSI, KPA, BAR, KG/CM²;
• Measuring range: 0-150 PSI with precise accuracy of 0.5 PSI.
• Fast air pumping: quicker inflate the P195/65R15 car tire from 0 to 35psi within 5min.
• Simple to operate: Start with your car engine first and plug into any DC 12V cigarette lighter socket
• Wide use: Use for 12v Car, Sedan, Bike, RV, SUV, and ATV. Also, sports equipment and inflatables (adaptors included).
Specification
Model No.ES-2403
Air Flow30 L/Min
Max. Current14 A
Max. Pressure150 Psi
Diameter of cylinder30mm
Inflation timeinflates a tire 195/65R15 within 5 minutes from 0 to 30psi
Air Hose0.75m high quality rubber air hose
Power Cord3m cord with cigarette light plug
Nozzle3 Pcs
Dimension220 x 120 x 175 mm
Weight2.0 kgs
Housing materialMetalDigital Air Compressor price
website:http://www.besttireinflator.com/air-compressor-tire-inflator/digital-air-compressor/
1 - 1 of 1 Posts
