Did this a little more than a month ago, but I didn't post here. Some of you may have seen my post on Reddit or Facebook (POLESTAR MODS Group).
I basically made my own side skirts for the Polestar 2. The skirts were originally for a Dodge Charger RT / SRT with the wide body style, these skirts I purchased from NINTE Shop which are from China, are made of PU Plastic and are relatively easy to bend, cut and modify. The overall shape of the skirts matches the curvature of the Polestar 2 under rocker quite well with the exception that the Charger is much longer in terms of wheelbase, so I had to remove and cut on both ends a combined 8-9in off. I then bonded using epoxy adhesives, some filler and sanding to get the ends looking smooth, painted and finally painted with a clear coat.
Basically it was fairly easy but the results were rewarding, it matches the CSR Automotive front lip quite well (it's not perfect) but it gives it more completion with it going further around the body. My next project before winter hits is the rear bumper, I like will keep this one simple and clean so that it doesn't look over the top. I want it looking as close to OEM as possible.
