Can you double check? For some reason the left side is harder to latch and gets stuck halfway if you don't notice it.Yes both sides are latched.
So this is actually a little bit outboard of where the manual suggests you push down. There isn't support under the skin of the hood there, you run the risk of denting it.I always close the bonnet by pressing lightly on the bonnet with both hands just above the two latches.
👍Thanks for the information about where to apply pressure to close the bonnet. I never read the manual, I've been applying just enough force to close it without denting it yet.So this is actually a little bit outboard of where the manual suggests you push down. There isn't support under the skin of the hood there, you run the risk of denting it.
