There is a tow bar option in the EU.(although apparently no towing package available???).
You need to go through all the selections, create an account, pay the deposit, and only then do you get taken to the options page like Tow Bar, Roof Racks, Cat Mats, etc..
It's only a 750kg Tow Bar with a nose load of 45kg. So basically exactly the same as the I-Pace.
so 1 hour faster than the slow ones. So in (simulated) practice, it's not an issue except with the Kia and the standard range Mustang.
what do you mean with 'cushion exertions'?
This is manually adjusted so "Seat Memory" won't work on it, but if you have long legs this extends the seat so it supports under your knee/thigh better.
As for trips ... this 1300km trip (800 miles) would you do this in one day on a continues drive? How many times a year would you make this trip?
The reason is if you make this 3-4 times a year and you want to do in one day, then honestly get a Model 3 LR. If this is critical then there is no better car for it.
If you make this once a year in the summer then honestly as per your ABRP showed it will make little difference overall, even 30 min's difference over 13-14 hours drive is nothing in reality. It's all abbot good planning and making the big stops to eat. Plus if speed / time is important, then charge to only 60-65% and get down to <10% before the next charge - this minimises time spent charging.
Note that ABRP doesn't have all the data for charging curves for the Polestar or ID.3 at the moment and they are very optimistic on times, 30mins can easily become 45mins.
I was very close to putting an order in for a Mach-E so did a lot of research, what killed it for me was the tow bar didn't meet my needs and at the time in July 2020 the Mach-E in the UK was "early 2021" which meant I had no real idea ... now it looks like realistically Easter 2021 for the UK.
