1 - 20 of 36 Posts
This is my first Volvo car, either original or subsidiary, so the answer to my question my be hereditary. But why, do we push the gear lever forward, to go backwards and pull it back to go forwards? Seems counter intuitive, no? o_O
My current girlfriend had the same issue. I thought it was due to the fact she's not used to driving autos
Felt very natural to me this weekend.
Reactions: Terran
hehe I was about to say that yeah thats backwards. (only had Volvo's with manual stick before)
Then my brain started working and I suddenly realiced I have that today on my BMW
Reactions: PCR
It's the same on all Volvos, not sure why, I questioned it (to myself) when I got my V90 but learned to accept it. I don't have to think about it anymore, it's in muscle memory.
One thing I noticed on the P2 test drive was a nice improvement over my T8 in that the P2 gear selector has two clicks in each direction whereas the Volvo has only one. This means that in the Volvo you have to pull the gear lever twice to get moving P>N>D but with the polestar you can just pull it all the way once P>>D (via N in the first click).
It's the same as this on all (German) autos / semi-autos I've had too.
When driving & resting one's arm on the lever whilst using the tablet, has anyone else accidently nudged the lever forward when going over a bump? You're not going to throw the car into reverse at 30mph but a little button on the lever to click to access reverse gear (like most cars) may have been an option. But the lever would maybe look a bit less cool so forget it!
It is common with automatic gear - and it stems from stupid history. Imagine Polestar would do it otherwise. Then we would have a never ending discussion.
To overcome this it would be needed to have total different approach. E.g. 2 switches instead of the ugly lever.
This is the standard direction with every auto car I've had - BMW , Audi and VW
Or skip levers and buttons entirely and just use the google assistant. Make sure to say please
Discussion Starter · #13 ·
My last auto, Jag F-Pace had a very intuitive round knob which you rotate (one stop) to D or R. I'm sure I'll get used to it but @dave is right, its easy to shift it when resting your arm to tap the screen, then see the error message on the screen.
1795
I loved my Jag with this .... however Jaguar have now moved away from the dial on the newer cars 😢
Midnight Charcoal non-PP Towbar
I think the I-pace has buttons as well from memory (it was 18 months ago I test drove one).. I've also never understood why it's 'backwards' on autos, someone somewhere either thought it was a good idea or a wicked joke..
That's the one on the Nissan Leaf :)
Semi automatics which are not flappy paddles: eg in rally cars use push forward to go down a gear.
In my mind this is because when you're braking the momentum inside the car (in your frame of rest) is moving 'forwards'.
1 - 20 of 36 Posts
