Only time I’ve noticed it has less effect is when there’s four adults in the car.
I sometimes feel I'm imagining it and then all of sudden I have an "oh sh ..." awakening.Wether there’s a leading car or not seems to be a factor for me, but I might be imagining things.
At highway speeds it seems that lifting off the accelerator pedal leads into more regen when there's a leading car compared to when there isn't one. It's less obvious at lower speeds.I sometimes feel I'm imagining it and then all of sudden I have an "oh sh ..." awakening.
How do you think does a leading car factor in?
I'm not sure, but it seems fine if there is no leading car, but tries to run into it if there is?
That was always the case, although they did tweak the curves a bit over the years (really liked the very aggressive regen on original firmware from 2020).It feels speed related to me
More Regen at higher speeds (that gets feathered in gently so sometimes it takes a second)
Regen trails off to zero as speed goes to zero
I don't think there's anything else going on other than that feathering in the Regen and varying it by speed
That is it. That is exactly it.My concern is that since 2.7 there's another factor other than just speed that affects how much regen is applied when lifting off, and it's not obvious what that is (presence of leading car might be one of them) but the end result is that it is no longer consistent and I hate this. When approaching a roundabout I lift off the accelerator and the initial coast time (introduced in a previous update) doesn't feel consistently long, as is the amount of regen. I used to be able to eg control stopping at a T junction just by lifting off within a few meters, that isn't possible, I often end up needing to apply some acceleration input if it surprised me with more regen, or apply some brakes if it coasted more than I expected it too. Overall not as great an experience as before.
Yes, I have observed the exact same thing. It happened a couple of times after 2.7 was installed. Then for quite some time everything worked fine, to the point that I started to believe that it was just my imagination.It has been discussed that s/w version 2.7 again reduced the regenerative braking with OPD and that is a pity, but I'm experiencing a serious issue with it as well. The regenerative braking with ODP (standard) is unpredictable. Sometimes you get what you would expect and sometimes there is virtually nothing. I have had several situations where I had to unexpectedly use the brakes because regen just did not kick in. Not often, but often enough to be wary of the OPD function now. I can't figure what circumstances make this happen.
Just me?
PS
No, I'm not taking about a full battery or extreme temperatures. Mid drive, one moment is fine, the next is not.
I have the same problem. Some times it's strong the next time I slow down it is very weak.It has been discussed that s/w version 2.7 again reduced the regenerative braking with OPD and that is a pity, but I'm experiencing a serious issue with it as well. The regenerative braking with ODP (standard) is unpredictable. Sometimes you get what you would expect and sometimes there is virtually nothing. I have had several situations where I had to unexpectedly use the brakes because regen just did not kick in. Not often, but often enough to be wary of the OPD function now. I can't figure what circumstances make this happen.
Just me?
PS
Stories like this are not boding well for the future of OPD. Already incidents in China are causing authorities there to consider banning OPD.I also noticed this recently, especially when lifting off the pedal at higher road speeds. It seems I've had to apply the brakes more often than I used to. I can't relate this to any particular software upgrade, though.
This may be a safety up-grade that Polestar isn't really willing to admit to. For example, we recently had a Tesla driver who apparently fell asleep while driving and the car came to an immediate stop in the middle of a highway. The accident killed the Tesla driver and severely injured other drivers. There was no time for the driver aids to alert the driver before the car just stopped when the driver's foot lifted from the power pedal.
Full regen may not be the best idea at speeds over a specified threshold.
Not nearly as much as with the p2 😂Wait until people realize how much variation there is in an ICE powertrain with a slushbox automatic.
