Wish we could select the temp for pre-climate like pretty much any car that has a pre-climate type feature.. seat/steering wheel selection added into timers would also be an improvement
No OTA, just for workshops.Any idea if this one is going to be released via OTA or workshop?
Any indication when it will available in the workshop? Time to call the service center. I want an ACC improvement.No OTA, just for workshops.
Yeah the fact that is runs 5-8km/h over even on the gentlest of slopes is pretty poor. Especially when this would be a simple software tweak and the little bit of extra regen would be a positive thing anyway.That's awesome if true. The ACC is way to variable on uphill/downhill, hopefully it will stick closer to the preset and doesn't prioritise efficiency, or at least gives us the option to toggle.
Especially down here in VIC where like 2km over is fine territoryYeah the fact that is runs 5-8km/h over even on the gentlest of slopes is pretty poor. Especially when this would be a simple software tweak and the little bit of extra regen would be a positive thing anyway.
You get a fine for going over 2km/h the posted speed limit?Especially down here in VIC where like 2km over is fine territory
In some states they show a bit of common sense but in others there is zero tolerance. Thankfully there is a bit of leeway in mineYou get a fine for going over 2km/h the posted speed limit?
I prefer the zero tolerance approach due to the number of muppets on the road. A mandatory IQ test should be taken prior to driving test and anyone who scores in the imbecile range should be sent to work at a nuclear reactor without any protection.In some states they show a bit of common sense but in others there is zero tolerance. Thankfully there is a bit of leeway in mine![]()
Yes, it would.I assume the 2.5 updates will be rolled in with 2.6? I'm currently on 2.4
This is good, though the seat and steering wheel heating is fixing something that previously existed/worked.
From fixed cameras they have 2km and 3km for mobile cameras as a tolerance for measurement error. There’s in theory an undisclosed tolerance on top of that, but I’ve seen a fine issued for 64km/h detected, 61km/h alleged indicating that at least for my state, it’s likely bullshitYou get a fine for going over 2km/h the posted speed limit?
Uk Fixed Cameras have a tolerance of 10%+2mph (allegedly) so in 70mph zones 77 should trigger the camera. I always just stick to 72 so when ACC increases speed on a downhill section it won’t go past 74mph.From fixed cameras they have 2km and 3km for mobile cameras as a tolerance for measurement error. There’s in theory an undisclosed tolerance on top of that, but I’ve seen a fine issued for 64km/h detected, 61km/h alleged indicating that at least for my state, it’s likely bullshit
Years ago, it was explained to me that in the UK in a 70 mph zone, if you were measured at 80 (1 mph over 70 + 70*10% +2)fine issued for 64km/h detected
Agreed, there’s no reason for it to not be able to hold the speed better on inclines.That's awesome if true. The ACC is way to variable on uphill/downhill, hopefully it will stick closer to the preset and doesn't prioritise efficiency, or at least gives us the option to toggle.
