PPF - It does work 99% of the time. There is always going to be that one stone that could get through 12" of steel! However it's only is recommended for 3 years then you need to get it removed and reapplied.
Note: A coloured wrap isn't necessarily full PPF - PPF will self heal if left in the direct Sun light if the chip or scratch is not too bad. Wraps are just plastic colour wraps mostly.
Ceramic - Lasts from 3-7+ Years
(depending on brand and level) - I had this done on my Jaguar I-Pace (
I'll add pic's below) .... was awesome. Doesn't stop chips
(but helps a little) ... did help when someone tried to key my car ... got the coat but not the paint.
Defiantly does make it easier to clean and wash. Finally at the start of lockdown my Stinger (
which I also had done) was parked at an odd angle ... was going to move it at the weekend but first lockdown kicked in so it stayed there. At some point a bird shat all the way down a side I could not see - we are talking bigger than your hand! Was there for a week. When I finally washed it off there was still a paint discolouration where the poo had been. I spoke to my Ceramic Specialist he said wash it a few more times and use a very clean microfibre cloth as hard as I could on that area.
2nd wash and it was like new again!
The best protection is as you have mentioned ... PPF the front bumper/bonnet/wing mirrors then Ceramic the whole car (
including the PPF'ed sections)
So both my F-Pace and Stinger got the same Gtechniq treatment. The Jag still had a load of stone chips ... the Stinger had none
(except on the windscreen 2 days after new!). The Jag was only 1 year old when it was stolen yet the Stinger was 3 years old. I suspect the F-Pace being a giant box on wheels didn't help with the aerodynamics - or I get really lucky/unlucky with one of them!
I was planning to get the P*2 just Ceramic coated again....but already seen a few chip reports from Facebook so now I'm worried that front end is too slab like and maybe I'll do the same as you - but then I'm like do I want to spend £1500 - £2500 on getting both. BTW a full car PPF is £3000+ just on it's own - if I owned a £200k car I would do full PPF!
I can totally recommend a top end Ceramic Coating ... like Gtechniq Crystal Serum Ultra and being professionally applied - note these take 2-3 days inside to "bake/harden" on to the car. The Paint pops and it's dead easy to keep clean, protects against things that would discolour the paint, including UV's.
PPF I've never had done, but when researching for the Jag if paint protection is 100% important then this is it if you get the right self healing top end stuff.
Doesn't stop everything sticking to the car
