I'm curious what the use case is for this.
I assume while playing sports somewhere with no lockers, like an outdoor field?
That's a bit poor. If the car is in "TOW MODE" (i.e. fooked) that should allow Polestar OTA/Roadside Assist to connect to it and provide an override until it went to a workshop for repair.
No key, no recovery is just bonkers.
That's of no use if the 12V battery has gone flat, which is a common end result when things go wrong. You need the physical key that's in the fob and can be pulled out when required.
Myself, I see the "phone as a fob" as a novelty for when it works. I'll always be carrying the sports key or probably even the full key, since when the car decides to flatten its 12V battery, you need the physical key to get in, pop the bonnet, get to the 12V battery and jump-start it to get it going again or allow it to be pulled onto the recovery truck.
Tesla deliberately provide a credit card sized RFID fob purely because it can sit in your wallet; sadly Polestar give you a small house brick!
