My original wipers were on their last legs I wanted to go with something better than OEM. I was able to get some PIAA Si-Tech blades on the car. OEM sizes are 19" and 23" but PIAA only makes 22" & 19" so that's what I used. The shorter drivers side isn't even noticeable. Parts numbers are - 97055 & 97048. I got them off amazon for about $70 for the pair.
Install was pretty easy once I figured it out. The supplied adapter needs a tiny modification to clear the windshield sprayers. Instructions below-
Remove the original adapter from the blade by pulling up on the side where the PIAA logo is
Now snap in the "M" adapter
This is the little guy you need to snip off. Known as adapter "B"
Then snap that over the M adapter and you're ready to go
