1 - 20 of 32 Posts
· Registered
I've been trawling the internet for a while trying to find the interior dimensions of the P2, specifically the rear bench. I found this image on polestar.fans
Looks like the interior is similar to a Volvo S60, within an inch all around of the Model 3 - some bigger (width) some smaller (leg space, though with better hip/thigh angle on the sides), and a bit smaller than an XC40.
Disclaimer that I don't have this from a direct source. But spot checking against other sources it seems accurate.
282
· Registered
It looks like the "1859" indicating the width for this pic is the same as "K" in the manual of just "width" - not sure what it's actually meant to indicate here but something that precise shouldn't be coincidence? Also not sure what "1800" is here as there's nothing of that dimension in the manual.
Else things like the rear/front track, wheelbase, and length match.
The height here of 1479, is roughly halfway between the heights with/without performance pack in the manual.
· Registered
What is disappointing is the ground clearance. The P2 with performance pick is at 146mm. Given the car is comparable in performance to the BMW M3 or Audi RS4 with 126 and 105 respectively, at 146mm the P2P looks like it's on stilks. May have to think about lowering on the Ohlins.
· Registered
Updated: Found an original source. This is from the Polestar UK Press kit so presumably it's accurate!
301
· Registered
Void | PP 350kW | Slate+Black Ash | No tow | Stickerless | IGL Kenzo graphene coating
I am looking into getting a custom mattress, or perhaps find something that will fit in the car. So, I did some measurements. They are just approximate values as measuring is hard with all the curves and edges. Anyway, might be helpfull for others so here it is.
1138
1137
· Registered
What is the measure between ground and door when having door open? Can anyone please measure this for me on both front and back door?
· Registered
LRDM, Pilot, Plus, Midnight, Sep 2022
Reactions: Hirudin
· Registered
The car is a little high, but I kind of like that. I'm sure someone has already lowered it significantly and it probably looks great.
For me the worst dimension of this car is the wheelbase. It's very short. There's a bad bump on the way home from my grocery store and the bundles in the trunk sound like they fall off a cliff if I go over it too fast.
· Registered
Polestar 2 Dual Motor Launch Edition 2021 - Void
Hi,
Why do you write 40cm (45cm) ?
I have a Powakaddy CT6 golf cart, it needs 45cm height. Will it fit ?
And a Ping driver ?
Thanks
My bag (strapped for carrying) fits behind the grocery shelf divider, however the car is not wide enough for my driver and 3 and 5 wood to fit back there. The have to be at an angle so that grip falls in the little alcove to the right. But this interferes with the divider, so where I have my bag in the car as standard, my driver, 3 and 5 wood are not in the car at the moment.
· Registered
Hi,
And a Ping driver ?
Thanks
Here is my setup, little bit smaller than I expected in the back. So although my bag is almost always in the car, my woods aren't because I do use the divider quite regularly.
Tire Vehicle Car Automotive tire Automotive lighting
Motor vehicle Car Luggage and bags Hood Trunk
· Registered
Many thanks for your reply as a true golfer ;-) but can you give the height (I wish I can put my CT6 in the trunk), thnaks.
Car Vehicle Motor vehicle Trunk Automotive exterior
· Registered
I have taken out the tape measures, and it gives me 41cm both for the side and middle.
Obviously, if you take out the parcel shelf, you'll have a lot more space upwards.
Vehicle Motor vehicle Trunk Bumper Car
1 - 20 of 32 Posts
