1 - 19 of 19 Posts
Just found this page...
It's a solid PDF with lots of technical data in, including the make of electric motors, wheel sizes, drag coefficient, 3-year limit on free internet access and more...
I've copied and pasted the contents here for the searches to find.
Polestar 2 – Technical Data (Europe)
Chassis and body
Body Type Steel CMA platform, steel body
Wheels, tyres, brakes, suspension (standard)
Wheels and tyres
19” alloy standard Michelin Primacy 4 (245/45R19)
20” alloy optional Continental PremiumContact™ 6 (245/40R20) optional
Brakes Standard callipers (front & rear)
Discs (front and rear) 345x30 mm and 340x20 mm
Turning Circle Kerb to kerb: 11.5 m
Suspension McPherson strut (front) , Multi-link (rear)
Optional Performance Pack additions to standard car
Wheels and tyres 20” forged alloy
Continental SportContact™ 6 (245/40R20)
Brakes 4-piston Brembo front callipers, standard rear callipers
Discs (front and rear) 375x35 mm and 340x20 mm
Suspension Öhlins Dual Flow Valve (DFV) manually adjustable dampers
Details Golden brake callipers, valve caps, seat belts
Electric motors (2)
Type AC synchronous, permanent magnet
Valeo-Siemens
Power 2 x 150 kW = 300 kW (408 hp)
Torque 2 x 330 Nm = 660 Nm (487 lb.-ft.)
Efficiency – standard car without extras
Energy consumption (weighted) 19.3 kWh/100 km
Range (combined) 292 miles WLTP
Range (city) 348 miles WLTP
Drag coefficient 0.278 Cd
Transmission and powertrain
Type AWD, up to 50/50 split front/rear
Gearbox Single-speed
Battery and charging
Type 400V Lithium-ion
Capacity 78 kWh
Construction 324 pouch cells in 27 modules
Charging Capability AC: up to 11kW (1 or 3 phase), on-board charger
DC: up to 150kW
Charging Times 40 min DC 0-80%
Performance
Top speed 127 mph
Acceleration 0-62 mph: 4.7 seconds
Dimensions and weight
Wheelbase 2 735 mm
Length 4 606 mm
Height 1 479 mm (1 473 with Öhlins suspension)
Body width 1 985 mm (including mirrors)
Ground clearance 151 mm (146 mm with Öhlins suspension)
Kerb weight 2 123 kg
Weight distribution 51% (front), 49% (rear)
Capacities
Front storage compartment 35 litres
Rear luggage capacity 405 litres with seats up (incl. 41 under floor)
Cargo capacity 1 095 litres with seats folded, to roof (incl. 41 under floor)
Standard equipment
Electronic climate control, 2-zone
CleanZone with pre-ventilation, multifilter
Full parking climate including preconditioning
Heated front and rear seats
Windscreen washers (heated nozzles)
Rain sensor
Heated steering wheel
Alarm
Interior alarm motion sensor
Double-locking door locks
Alarm inclination sensor
Two Polestar remote key fobs and key tag
Keyless entry with handsfree boot lid opening (with extra-wide foot sensor)
Electric tailgate with soft closing
Panoramic roof with projected Polestar symbol
Charcoal headlining
Tinted rear window
WeaveTech (vegan) upholstery with Black Ash deco
Powered driver seat, with memory
Powered passenger seat
4-Way power adjustable lumbar support, front seats
Mechanical cushion extension, front seats
Rear seat 40/60 split
Hexagonal shaped gear shifter with illuminated Polestar symbol
Textile floor mats
Frameless side mirrors, electric and heated
Automatic dimming exterior and interior mirrors with new grey tint
Pixel LED headlights
Active Bending Headlights with Cornering Lights
High-pressure headlight cleaning
High-level interior illumination
19" 5-V Spoke Black Diamond Cut Alloy Wheel
Front storage compartment (35 litres)
Rear cargo floor with multi-functional cargo divider, bag holder and 12 V power outlet
Tyre repair kit and jack
First aid kit
Warning triangle
Adjustable speed limiter with speed sign support
Adaptive Cruise Control (switchable to conventional cruise control)
Blind Spot Information System with steering support
Cross Traffic Alert with brake support
Rear Collision Warning and mitigation
Collision avoidance and mitigation by braking and steering
Run off road mitigation
Forward collision warning
Lane Keeping Aid
Driver Alert
Road Sign Information
HomeLink™
360° surround view camera
Front and rear parking assist
Hill Start Assist
Driver and passenger front airbags
Side airbags
Inner-side airbags
Curtain airbags
Whiplash protection, front seats
Cut-off switch, passenger airbag
Alcolock preparation
ISOFIX for rear seats and front passenger seat
Harman Kardon Premium Sound with 13 speakers (600W) including air-powered subwoofer
Digital radio DAB+
Progressive 12.3-inch digital driver display
11,15-inch centre display
Inductive phone charger 15 W
4 x USB-C connectors: 2 front, 2 rear
Infotainment system powered by Android incl. Google Assistant, Google Maps, Google Play Store
Over the air (OTA) updates for lifetime of the vehicle
Google service connectivity included for 3 years
Polestar Connect
One pedal drive, adjustable
Adjustable steering force
Electronic Stability Control (ESC)
Indirect Tire Pressure Monitoring Systems (iTPMS)
Charge cable 4.5m, IEC 3P 230V, 16A 11kW, Type 2, Mode 3
Charge cable 7m, IEC 1P 230V, 10A 2.3kW, Schuko, Type 2, Mode 2
Future additions via OTA:
Polestar Digital Key (later in 2020)
Connected Safety (later in 2020)
Apple CarPlay (mid 2021)
Standard vehicle (measurements in mm)
2919
With Performance Pack (measurements in mm)
2920
Chassis and body
Wheels and tyres
Electric motors (2)
Valeo-Siemens
Capacity 78 kWh
DC: up to 150kW
Performance
Top speed 127 mph
Wheelbase 2 735 mm
Length 4 606 mm
Capacities
Standard equipment
Rain sensor
Alarm
Charcoal headlining
Tinted rear window
Textile floor mats
First aid kit
Warning triangle
Lane Keeping Aid
Driver Alert
HomeLink™
Hill Start Assist
Side airbags
Inner-side airbags
Curtain airbags
Digital radio DAB+
Polestar Connect
Interesting they have different wheels in the UK for 20” nonPP
here it’s Michelin touring A/S tires for the 20” noPP. But the same Primacy4 for 19”
3 phase cable? I don't that was what was delivered with the car.
IGNORE THIS - I got it wrong!
There's this as well:-
Pages and pages of stuff including presently nonexistent features such as:-
Personalised Lighting
Polestar 2 allows its users to adjust and play with the colour balance of light inside the vehicle. The standard colour is 5,000 Kelvins – intentionally the colour of Polaris, from which Polestar derives its name. This interior light colour temperature was chosen to compliment the Polestar 2’s minimalistic, simple, modern and elegant design theme. However, Polestar 2 allows individual users to change the colour temperature to their liking. Upon doing so, the vehicle always recognises them with their preferred illumination colour balance when their driver profile is activated.
USB-C Connectors
Four USB-C connectors (two in the front and two in the rear) allow the driver or passengers to plug in devices to charge without utilising the inductive charge pad. These connectors also allow passengers to stream their music from their devices via hardwire to the Polestar 2’s Harman Kardon 600-watt premium audio system.
Acoustic Vehicle Alert System (AVAS)
To alert pedestrians and cyclists to the quiet Polestar 2’s presence, AVAS creates a subtle and natural sound while driving. Forward driving sounds are active between 0 and 19m mph. In reverse, the sounds are always activated, increasing in volume when the vehicle is moving.
I did actually notice the reverse beeping for the first time the other day. When the doors/windows are shut you cant hear it at all, but my dad was backing the car onto the drive and I noticed it. Still very quiet. Not noticed it moving forwards however.
This data is great, should be a link from their marketing site! Also noticed this:
'Repairs to the battery, if ever needed, will be handled by Polestar. The repairability of the battery reduces potential out-of-warranty ownership costs, but importantly also reduces Polestar 2’s environmental footprint since the battery can be repaired rather than simply replaced.'
and wondered if this was common to other electric cars (e.g. Tesla) ? Does anyone have any information?
USB-C Connectors
I've had a bee in my bonnet about not being able to play media via the USB connectors. Perhaps this will be activated with an OTA update? We shall see...
Interesting that the ride height of the PP is lower, but they don’t mention different springs or spring rates anywhere.
Michelin Primacy Tour if that makes any difference.
That bee has been in my bonnet too 😆. Today I got fed up, and for a nice Sunday drive (on Saturday) I just selected an album on my phone and played it via BT. First time I've ever enjoyed music in the car.
Wondering what CS told potential buyers on the phone in the UK around what type of tyres (y not i) they would get with the different types of wheels... 🤔
Discussion Starter · #16 ·
Sadly people in the UK (bit of a generalisation here) are uninterested in tyres, having been brought up with a lazy industry that just wants to keep selling summer tyres. They're seen by most as an annoyance that you have to pay for far too often and so far too many people fit cheap junk when they've turned bald, as far as I can see.
Ok, somewhat of an exaggeration, but I think it's fair to say the Brits just fit tyres that are from a brand they know and at a price point they feel comfortable with. Sadly the concept of swapping tyres or wheels is just ignored (as are the facts over temperature behaviour of rubber). All season tyres are slowly starting to pick up in the UK but at this rate I'll be dead before they're the standard and I'm not even 50 yet!
So what I'm saying is I'd bet no-one (other than the well-informed we have on this forum 🙂) even asked what tyres the car came on, they're only interested in the wheel size. Maybe 0.1% of people would have complained if it came on "Striding Unicorn Winds" Chinese brand tyres instead of sitting decent.
magnesium/slate/19"/tow/18xxx
As we're sharing knowledge (or the lack thereof) on tyres, let me share the general view on tyres in Belgium. For the last 20 years BE has been company car paradise. By contract they get summer tyres and have them swapped out for winter ones when it gets 5 degrees or less, or if you plan a trip to hilly regions.
The lesson learned is that the braking distance is shorter on winter tyres when it gets colder. Even on non-icy roads it makes a difference, it really is due to temperature. The compelling factor for summer/winter swaps: safety. 50 centimetres make a live or die difference when suddenly stopping for a crossing pedestrian or a cyclist wobbling about in the bicycle lane.
And when it comes to tyre costs... when you're on winter wheels, the summer tyres don't wear out. You just have the hassle of swapping wheels/tyres.
Frankly I don't think it's a whole lot better here in the US. I for one, have had a friend in the tire business for over 40 years and so I happened to be very much into tires and understand the difference between them when I put better ones on.
Unfortunately, I loved it every spring when I put my summer, staggered, wheel set on and my previous car just felt so much better. It was wonderful.
But now, my winter tires are excellent and I'm using the same OEM rims... so the change in how the car drives just won't be as exhilarating. (First world problems, eh?)
1 - 19 of 19 Posts
