1 - 9 of 9 Posts
I got it to work with a mirror tap...
Just plug the Red into the Green/Black wire and the Black into the Yellow/Black Wire...
Petal Gesture Terrestrial plant Finger Plant
I installed the FitcamX and just plugged it in to its own wires which are red/black...
Hand Hood Gesture Finger Gadget
It works...
Vehicle Automotive lighting Motor vehicle Automotive mirror Hood
2022 Midnight Polestar 2 DM Loaded + Leather, 2019 Mazda Miata RF, 2013 Volvo C30 PLE 166/250
Nice!
Reactions: CtK
It works...
Thanks for the write up, but I bought the same mirrortap and tried to plug in as you explained. Oddly, my radar detector does not turn on and won't power up, but my windshield wiper start going full blast when I do so! My colored wires are slightly different than yours with more of a turquoise blue wire on the end and a yellow black wire in the middle. Anyone else try this and have the same issue? Any ideas of where else I might be able to tap into one of these plugs behind the mirror?
Hmm you mean turquoise and blue wire?? My first pic shows a turquoise(greenish)/black wire). I just switched to a different radar and it still works, so not sure why it's not working for you. What radar detector are you using??
Yep, that is the wire. Your photo made the shade look a little bit different than mine so I thought perhaps there was some change in model year 2022. In any event I'm running a Escort 360 Max. I have used mirrortaps in all of my other cars, including two Cayennes, a 911 and a Macan. Never have had this weird issue before and I'm wondering if there are other wires I can tap in that same behind mirror area. If it makes any difference, my car only has the Plus package. I am totally mystified.
Wood Bookmark Gas Electric blue Wire
Sorry im not sure what the issue is. Maybe check the fuses or if you know how to use a multimeter and check if the wires are giving out power. I also have Plus and Pilot packs.
1 - 9 of 9 Posts
