Don't you have to go get a carton of milk or something? Maybe in the next town over where they have better milk? Of course, the really good milk is about 100 km away on the other side of that forest with the twisty roads.Just arrived today.
Car matches the house nicely tooJust arrived today. Still getting to know the car but all seems well so far. No jack or first aid kit, Plugsurfing card present, No scratches around gear selector, keyless entry and boot operation is fine, Charging at 7KW works fine using tethered home charger, 360 camera excellent, Very poor EE reception here but connected fine to phone hotspot for better data connection. Haven’t tested headlights yet. The ride seems slightly harder than I remember from the test drive so I wonder if the dampers have been set to 8 and 8 instead of 12 and 12 on the test drive cars.
Cheers. Good to know! I'm getting one installed soonI can recommend the Andersen charger. It isn’t the cheapest, but it looks good and works perfectly with the Polestar. Charging was set to stop at 80% which it did.
Yes, parts of them are a similar gold to the calipers but they’re mostly hidden.are the Ohlins Damper actually gold in color like all of the Media Pictures shown
Is a stop at 80% best for battery health? If so I'll plan to do the same. I only need about 200km of range per day.I can recommend the Andersen charger. It isn’t the cheapest, but it looks good and works perfectly with the Polestar. Charging was set to stop at 80% which it did.
Yes, Keeping the battery between 20-80% and not using rapid chargers is the best for battery maintenance.Is a stop at 80% best for battery health? If so I'll plan to do the same. I only need about 200km of range per day.
If it's anything like my VW you will only have a short time to disconnect the cable before it relocks automatically. Occasionally infuriating!Left the car charging overnight and went out to disconnect the charging cable this morning. Found that the car wouldn’t release the cable and then realised that it won’t release if the car is locked and the key isn’t nearby. Good security feature.
ThisIf it's anything like my VW you will only have a short time to disconnect the cable before it relocks automatically. Occasionally infuriating!
Both the front and back license plates are attached with 2 screws each. The screw caps are colour coded to try to match the registration.How is the Licensor's Plate Bracket attached to the front Fascia? Screw thru the bumper or Sticky Tape to the bumper
