161 - 170 of 170 Posts
Heavier car? Stickier tyres? Two motors -vs- one motor? Synchronous -vs- Asynchronous motors?
So many things could affect this. I have no doubt that with OPD off, the car is coasting as much as physically possible.
Yes. Yes. Yes. Not sure 🙂
I agree. What still perplexes me though is that my other car specifically regened a small amount while coasting in D whereas the P2 does not. I really wish the P2 had a specific numerical gauge for power being used or recaptured.
isnt this what OPD Low essentially is?
No. In the Volt it is much, much lower. It is designed to mimic an ICE coast where the engine provides some internal braking when you let off the throttle. It also has a OPD mode that is similar to Low on the P2.
@JRRF I think is talking about "almost" costing with a fraction of Regen - That's called OFF with the smallest amount of Brake Peddle 🤩
Yes. Although the Volt seems to go faster with that fractional regen than the P2 goes even with no regen.
When braking with OPD off, the white regen indicator goes to about 90% to the left before the orange mechanical braking indicator appears - BMS allowing. How much regen do you see?
They really should have named that option OPD instead of regen in the menu...
You are correct. I paid more attention and regen is pretty dramatic in that mode. OPD is really fun way to drive but nausea issue is still there. Curious is there will be any noticeable difference in range. I tend to doubt it after limited experience so far.
Perhaps you should read through the rest of the posts @Samiam :)
Reactions: krheinwald
OPD Off maximizes efficiency
OPD Standard maximizes fun and the admiration of your peers
