1600W? Continuously? No way! Where did you get that number from?
It's an impossible number to pin down anyway as it's going to depend on so many other factors - it's not a constant.
Bjorn slept in the car in the artic circle ... kept weight on the drivers seat with seatbelt plugged in.
He consumed 16kw of battery over 10 hours, outside was -10 deg C. Therefore he used 1.6kw per hour .... sorry I missed a slash after the kw and before the h.
Now you could say the screen and other parts of the car also took some of the power, and/or that if the outside temp is higher then less energy will be used.
So I was using the 1.6kw/h for an example ... you are right it's not a consistence number because it will depend on the temperature difference, but I was trying to convey how much energy the car can use in winter to keep warm, hence why efficiency is lower than expected.
