Sorry that this happened. If you are willing to pull some panels off and disconnect a couple cables, there's a way to hard reset the TCAM, which will most probably fix it: 12V/TCAM BATTERY DISCONNECT PROCESS. It seems that most TCAM failures are due to software faults and not failure of the actual physical device.
When you say the "dealer", you mean the Space or the service center? The Space (at least here) isn't capable of doing anything. The service center will be able to do a hard reset. I'd make sure that either they or you try that before you wait for the replacement TCAM module and continue to lose use of the car.
And its just absurd that they do not have them in stock -- last time I was at the service center they said they, unlike the fully stocked Volvo part department right there, don't stock any parts and everything has to be approved then mailed from some secret bunker. I thought we learned a lesson about JIT logistics during the pandemic but apparently not!
