1 - 4 of 4 Posts
I cant get my trip computer up on display when I press the end button on the light stalk. Should I be doing something else?
Can someone also explain the 4g and WIFI connectivity please?
Is there a sim card supplied with the car to obtain wifi and Polestar Connect or do we just get 4g for that?
My handover driver did not really explain any of this.
You press the O on the right side of the wheel.
2413
To hide you press the >| button then the O again for confirmation.
4G is supplied by Polestar - There is no SIM card ... it's an electronic sim. Everything related to the Car uses this 4G/Mobile connectivity.
With WiFi you can connect the car to your house WiFi so it uses that at night do update/talk to the APP coming soon.
If you are referring to setting a Wi-Fi Hot Spot in the car so other people can connect to it while on the go, then you need to buy your own SIM and Data Plan - However not this feature is NOT live at present. It is meant to be a feature, but people that have inserted a SIM have not found anyway to set up an Hot Spot in the car.
Thanks GDank, that helps a lot.
1 - 4 of 4 Posts
