Not mine but ouch!
The only BMW to use an indirect tpms is the X5 for a few years in the early 2000's. Every other model, and the X5 after that, has used sensors in the wheel. Are you perhaps thinking Audi? Audi is an avid user of indirect tpms.Wow, seems like the indirect tpms sensors aren't working very well.
Bmw has used indirect for years and it's worked well, but maybe geeley hasn't figured out as
Absolutely! I would raise holy hell with the tire manufacturer. This just shouldn't happen unless the tire was seriously underinflated.The fact that these tire treads have completely separated from the sidewalls in a similar manner on multiple vehicles more concerning. Slightly under-inflating or slightly over-inflating shouldn't cause this problem, and you have to build up a hell of a lot of heat to break the steel and poly belts that fully wrap from the sidewalls and around the tread.
Yeah. But it sure looks like these are flat out failures of the tire manufacturing process, as opposed to some user error.There are no steel belts in the area where the tire came apart, FYI.
Hp/torque didn't cause the issue the OP showed. Driving on a low pressure tire, which causes an increase of heat to the point of failure, did.I keep on seeing statements in the media and this forum about EV's being heavy.
I concede that they are heavy but they are no heavier than many widely sold ICE vehicles.
The Audi A7/8, Q5/7, RS6/7
Toyota Sienna,
Infiniti QX60/80
VW Taureg
Volvo S90, XC90
and many more
weigh as much or more than a P2.
So the weight is not the key factor in EV tire failures but, as others have mentioned, the availability of substantially higher torque is likely the key player here.
Let's stop with this "our cars are heavy" talk and focus on the hp/torque.
Every tire has a load rating index on the sidewall. Are you questioning whether the OEM tire choices load ratings are sufficient for the weight of the vehicle?With EVs weighing more than normal passenger vehicles, tire manufacturers probably need to beef up their construction a bit, especially for sporty EVs like Polestar's.
Are you suggesting they made a tire for an EV and ignored important aspects of the car?Making special EV tires is different than building tires to withstand cornering and torque forces of a heavy EV with gobs of torque. While the Polestar OE tires are all XL and V rated, that doesn't mean they're necessarily fit for purpose. Paying tire manufacturers to design special tires (as Porsche has done for the Taycan) vs fork an existing design for noise reduction can mean a measurable difference in vehicle price.
Which they should have done all along given the nature of this market.This warning from the Polestar-specific Contis is instructive as to why some NA markets are now getting all season tires as standard on the 2024 models:
moot 😉mute
Automakers have to make all sorts of trades in design. They need to cut cost and keep margin high, while meeting regulatory requirements for the markets they sell in.Are you suggesting they made a tire for an EV and ignored important aspects of the car?
