Windows fogging up
1 reading
6.9K views 8 replies 8 participants last post by  davenport
The only way I can keep my windows from fogging is to blast the heat and make it unbearably hot inside the cabin. Is this happening to anybody else? What am I doing wrong? I’ve never experienced this in any other car I’ve driven.
#6 ·
I have experiencing that too here in the Pacific Northwest with our wet winter, but I have been using the eco mode on auto most of the time, the back window and the driver side window near the mirror area are the spots with more accumulation. I will try turning off the eco and see if that helps.
#7 ·
Are you just turning up the temperature or are you using the front defroster. When I hit the defrost button next to the volume knob it clears any fog almost instantly. Yes, the temp is set to high but I just lower it to 72 or 74 and leave the defrost on with eco mode and it works great.
#8 ·
I've been getting more windscreen fogging recently, and the max defroster doesn't clear it at all. When I think back the max defroster has never been effective in my car. There's plenty of increased fan noise when I put max defroster on but there is absolutely zero airflow felt anywhere near the windscreen, not one bit. Does anyone get airflow out of the vents circled below??
I've got nothing coming out of any of them, regardless of whether I use the max defroster or taking climate out of auto in to manual and directing airflow to windscreen only, and increasing fan speed.
