Bigger frunk.
5.3K views 19 replies 14 participants last post by  Russ2
I moved this stuff to the rear under the floor.
= bigger frunk
#4 ·
After Day 1 I have never opened my frunk. I do keep the trunk spotless though, apart from the grocery shopping trips.
About the flat tyre stats. I reckon I must be about average, 2 flats in 32 years. My wife picks up nails and roofing screws in the tyres probably at a rate of 5 in the last 8 years or so. For a while I thought it was because her place of work was in a newly built development and fresh construction debris was the cause, but after 6 years it's getting harder to blame the builders. The other statistical outlier is how many of the punctures are at the sidewall shoulder so not deemed repairable, vs the puncture being in the body of the tread.
#6 ·
I did the same... like a week after I got my Polestar. Well... I didn't put it in the trunk tho... but in the garage. With the exception of the towing hook. Because let's face it... should I have a flat I would NOT attempt to fix it myself, but simply call road-side assistance and have the car towed.
I don't use the frunk TOO often tho... as the "WTF" stares by passersby kinda annoys me.
#10 ·
Same here, I put my cables and other non essential stuff (hivis vests blanket etc.) in the frunk and keep the boot empty for shopping etc. wouldn’t be a real hassle if I needed the first aid kit or tyre inflation or gunk and had to empty the boot first especially if on a long trip and it’s packed to the max.
#11 ·
Ditto.
The frunk currently contains the 3-pin 'granny' charger and the tire kit. The level 2 cable is under the floor of the boot, because the chargers in my building don't have tethered cables, so I'm getting it out regularly.
It's a nice to have for when you're struggling to get everything in, otherwise it's a bit pointless. The only time it's been used was my sister putting her bag in there for the novelty of it.
#13 ·
My front boot sits empty most of the time. My charge cable and road side LED lights are under the floor of the truck in the back. I have put a couple bags of groceries up front before. Only simple way to do that is pop the hood before going into the store so I can easily lift it on the way out. They can't slide around up front.
#20 ·
And what is a frunk anyway?
I assume people are talking about the Bonnet/Hood and Boot/Trunk? Front storage compartment if anything.
People haven't called a VW Beetle engine cover a Ronnet or a Rood.
Obviously the Gas pedal has now disappeared but the Accelerator almost remains but not when in Re-Generation mode because it is then a Decelerator. :unsure:o_O:)
