Home WiFi Issues - Polestar never sees the network.
Tags
wifi
21K views 26 replies 16 participants last post by  Knucklehead
Can anyone confirm if the Polestar 2 only supports 2.4 GHz connections? I saw some comments elsewhere. I've moved one of my TP routers three feet away from the car and it doesn't see it at all, so I'm sure it is not signal strength.
#3 ·
Make sure WPA is disabled, or - as Belac suggests - set up a guest network.
Worth pointing out that the guest network thing usually works because guest networks rarely if ever have WPA enabled though, and not for any other reason. So if you can, you might as well just disable WPA.
And yes, it's 2.4GHz only. In 2021.... Gotta use up that stock of old Volvo TCAM units somewhere...
#11 ·
There are two options, and I guess I'm not clear which you're interested in.
1. The car logs onto your home WiFi network (or tethers to your cellphone via WiFi).
2. The car acts as a WiFi hotspot.
In the case of #1, it's as I mentioned above, to allow for your car to use another network in place of its built-in cell/data connection. On Volvos people have used it for Sensus map updates, etc., because that's faster than the cellular data connection. I haven't been able to play around with it in a Polestar, but I assume maybe you could do the same for downloading offline Google Maps more quickly than doing the same via the cellular data connection.
In the case of #2, I think that's obvious, but unless you're really trying to save on your phone's data plan, or your phone has lost cell connection (and the car still has it), or you have devices that don't have a cell connection, then I don't see the value in having this turned on.
#18 ·
I can verify also my loaner is on the 2.4ghz when both 2.4/5 are available. It has downloaded 1.6gb of data though - probably YTMusic I just set up to cache music. Is it confirmed it can't pull OTA over the Wi-Fi? I live in an area with terrible cellular coverage (we used to actually have an AT&T MicroCell to alleviate the issue, until our phones were capable of wi-fi calling), so I'm concerned I won't get the OTA updates in a reliable/timely manner...
#20 ·
In my opinion, tether your phone and forget about using the useless on-board connectivity. I've had my car since October and can honestly say I can only recall two days in that whole time where my connectivity was fit for purpose.
I've given up trying to get it fixed (along with six different rattles)... Hey ho, only 26 months left on the lease.
#26 ·
WPA3 definitely does not work, but WPA3 also does not work on huge swathes of other devices too.
So very few people in a residential setting would have -only- WPA3 available. Would be a right pain in the butt.
Sure, you can use WPA3 in transition mode... which then allows WPA2 connections, but that's pointless because you have to enable 802.11w and any device that doesn't support WPA3 likely doesn't support 802.11w either! Not actually sure why it exists...
