Installation costs for home charger
4.8K views 10 replies 8 participants last post by  doughboy
Hi,
joined the forum yesterday as I've ordered a PS2 through the works car scheme.
While I wait on confirmation of delivery times, I'm researching the install of a home charger & trying to figure out the best option. From what I can gather, I qualify for the OLEV grant, and install should involve running a cable from my distribution box (I have a spare socket) of about 1.5m through an external wall, then wiring in the home charger to the wall. I don't see this being more than 1/2 a days work for a competent electrician so wondering what the installation costs typically are as they seem a bit steep, considering there's a ÂŁ350 grant. Without the grant, purchase and fit of the unit seem to be in the region of ÂŁ1000+?
Thanks
Ian
#2 ·
Assume the day rate for a decent installer is ÂŁ350 - whilst it might only take half a day, it also might not, and there will be travel involved. So no -good- installer will book two jobs in on one day. Anyone planning on doing two a day is going to be taking short cuts.
You've then got parts - you may need an additional consumer unit / Henley blocks / open-PEN detection unit depending on your charger. That's potentially up to another 300 quid.
Then the cost of the actual EVSE and you can see that you're easily into 1K+ pre-grant.
#3 ·
From ÂŁ199 (if you can get a 32A commando socket installed cheap) too ÂŁ1350+
Podpoint are in the ÂŁ500-600 range after grant discount and installed. Zappi around ÂŁ750.
#4 ·
Just cost me ÂŁ736 to get a Wallbox Pulsar Plus installed in my garage - run from existing garage fuse board, about 7m of cabling through one partition wall. Took him the morning to do it and he also mentioned to me he only books in one job per day. That was via Engage Services (Manchester).
#6 ·
Thanks All, very enlightening. I have a number of friends/family in the building trade, no electricians sadly, and ÂŁ350 a day is a vey healthy daily rate. :) I've just opened discussions with 'futurechargingsolutions', has anyone used these guys?
@GDank thanks for the link.
@356Pilot thanks for the tip on Engage Services.
I'll take a look at these. Essentially looking for a simple solution as most charging will happen at the works car park.
#10 ·
If you can charge at work, I would work out if you really need a box at home. We only use a granny charger using cheap electricity for 5 hours per night. Adds 10kw per night good for our average use. If we go further we can charge all night and add 30kw. Just a thought. We assumed we would need a box and had one on order. A cockup meant the order never got processed so we ended up using the granny charger by necessity. Soon realised it was all we need.
