Journey log messages
2.5K views 16 replies 9 participants last post by  polken
I noticed that at the start of every drive there is a message hidden behind the top bar. It is the journey log telling you it will record the ride. Unnecessary, distracting, dangerous. Is there a way to not show these messages short of uninstalling the journey app?
Reactions: banye
#4 ·
Journal fails to work for me after a few days and the only way to figure this out is that this notification is missing so I can start it again.
It happens often enough for me to consider it unfit for purpose (which is true for most of the Android side of the car) as I end up missing many trips until I realise it’s not working, even with the notification enabled to make it a bit more obvious.
#8 ·
Mine missed some journeys when it was first released but it’s been solid since. It behaves in odd ways although there’s some mildly tricky choices being made. For example, what a journey is - does it stop if you pull up to post a letter or do a quick errand? Or not capturing small journeys, I think it’s consistently not capturing anything less than 1km or so which is sort of reasonable until you stop near home to do a errand and that becomes your journey end. And that annoys me when I look at the data. Or, why it’s not recording the odometer reading or the SOC. Or why it’s not capturing charging?
#9 ·
All valid points and the answer is it’s just a disappointingly bad product to tick a box as it was a feature promised at launch. Not much thought appears to have went into it than ticking that box.
The fact that you can’t rely on it being accurate makes it pointless for the intended purpose regardless of how feature rich it is or isn’t.
