What has been your preferred setting for the 'One Pedal Drive' feature?
  • 'One Pedal Drive' Standard profile v2.4.
    Votes: 25 17%
  • 'One Pedal Drive' Standard profile v2.7.
    Votes: 8 5.5%
  • 'One Pedal Drive' Standard profile v2.9.
    Votes: 43 29%
  • 'One Pedal Drive' Low profile v2.4.
    Votes: 3 2.1%
  • 'One Pedal Drive' Low profile v2.7.
    Votes: 5 3.4%
  • 'One Pedal Drive' Low profile v2.9.
    Votes: 11 7.5%
  • 'One Pedal Drive' Off.
    Votes: 36 25%
  • I would prefer to set my own value. (added later)
    Votes: 10 6.8%
  • 'One Pedal Drive' Standard profile v1.8. (added later)
    Votes: 5 3.4%
  • 'One Pedal Drive' Low profile v1.8. (added later)
    Votes: 0 0%
Lets talk about the 'One Pedal Drive' feature!
28K views 175 replies 54 participants last post by  ChiMatt
#1 · (Edited)
The 'One Pedal Drive' feature is getting useless after 2.9 update, moreover it has gotten way too soft on this update specifically, even though I personally wrote Polestar about the first change they made on this lane when they change it from the good, reliable and stiff on 2.4 to softer 2.7, just like there was no 'Low Profile'. The 2.7 version had a softer regenerative brake even in the 'Standard Profile', which is the strongest value possible to setup for it that is user faced.
In the first 24hs after using software update v2.9 I had to slam the brakes twice on that day or else I would have crashed into the car in front because of this change.
Which begs the questions:
  1. What is the point of having a 'One Pedal Drive' feature if you have to use 2 pedals? None.
  2. Are we safer with this change? No, we need more distance and space in front of us to fully brake.
  3. What happened with driver's muscle memory after getting an update that changes the way we have adapted to learn? Muscle memory is useless now.
Let's review how this setting would it be in a world where drivers could actually customize their driving preferences:
Bottom left corner, in case it went unnoticed.
Adding a poll to get attention on what are drivers preferences on this regard.
Also, do you guys use the Low profile?
In my case I actually would prefer a value in-between 2.4 and 2.7 but the UI does not provide a way to let me set my preferred customized driving style for that matter.
Unrelated but since the feature is on the same screen and I have also stated the question to the Support Team: What is the purpose of a Creep function without 'auto braking'? No response yet.
#3 · (Edited)
Thanks! Updated!
I use OPD low, have done since I got the car, prefer the less invasive nature, behaves more like an ICE which is my preferred behaviour. OPD standard just feels wrong to me.
Perfect!! Remember to please cast your vote! thanks for letting others know!! Appreciate the feedback!
#27 · (Edited)
and I love using the OPD. I have hardly touched the brakes
I am in love with the OPD too!!! I wish I could tweak it to what it was before this current version, it was so much better!
So after my experiences it feels bizarre that people did not felt any difference at all when upgrading it, so I am not actually sure if they probably be using the 'Low Profile' instead.
#29 ·
Is there anyone at all that has actually done a quantifiable measurement of OPD performance before and after that has actually measured a difference?
I’ve only ever had 2.7. I measured my OPD stopping time, between 7.0 and 7.9 seconds going from 60km/h to 0. (Times varied depending on exact start speed and the final stop at zero was a bit fuzzy). This is with one person in the car on a flat road.
I’ll be remeasuring after 2.9 is installed and report back. In the meantime I’ll try to get more measurements.
#30 · (Edited)
Yep. I measured distance to standstill using low and standard settings from 40, 60 & 80 kph with 2.4 then an hour later after upgrading to 2.7. All were unchanged. Will repeat once 2.9 hits our locale.
I'd maybe believe you now have to lift your foot a little further to get maximum retardation but if you do it's very subtle and the maximum level of retardation is unchanged.
#48 · (Edited)
I could not be feeling more sympathetic to your words, this is the exact description of where I stand, v2.4 was excellent but now that they have been tinkering with it I want a piece of that too, now I want to be able to control how my car applies my own personal prefered strength of regenerative braking in the OPD, they opened the door and now it won't shut.
#36 ·
Sorry, not Trolling....
I've noticed no appreciative difference in the OPD and I drive around 150-180 miles per day. I did use the brake pedal yesterday but that was probably me approaching a traffic light a bit too fast? It seems to accelerate and decelerate as it did the week before the update.
#37 ·
Or the changes were made from a normal customer base opinion, and not from an enthusiast forum user opinion? I think Polestar have a set of average joe's out there driving around and leaving feedback. Do I assume correct that attached curves are what you think/feel is changed? If so, a "normal" user might feel they get better control if the OPD works like a brake pedal? The more you lift (or push in the "old" way), the harder it will brake? Or I misunderstand you. I got the car on 2.8, and been driving with 2.9 for a week now, and haven't noticed a change, and I only use standard OPD. But only had the car for 3 weeks prior to 2.9.
#52 ·
The thing I am experiencing is that now I can lift the pedal entirely, not just a bit, entirely and it feels more like you entered into neutral in an ice and then! it starts braking, and that is in the Standard the harder setting we got, in the old way I could fine control how much I wanted to lift the pedal, now I have to lifted entirely and start going for the brake because I don't know if the distance in front of me is enough for the regenerative brake amount being applied. So the convex curve you posted may seem the reason for this behavior.
I mean, if they would have done in the Low profile great! Because is a good learning curve for people transitioning from ICEs to OPD, but they didn't needed to mess with the hardest profile to do that.
#38 ·
I've not noticed any change since around P2.2, and as I've mentioned before, I travel down a steep hill every single day on ACC where there's a roundabout at the bottom where it's essential to come to a complete stop. I would -really- notice if there was some difference - and really did notice that one time they made a big change.
So it's either confirmation bias where people are convincing themselves that something has changed each time. Or maybe different cars have different hardware and have been affected in different ways by the software updates.
For me, I can categorically state that I have not noticed any change at all since this time last year.
#41 ·
I think I will start a new thread to sound out interest in a device that interfaces between the physical pedal position sensor and the car electronics in order to custom remap the reported angle versus the actual angle.
I will start a LLC to make it if I could get 400 customers willing to pay $399.95 USD (plus shipping).
#42 ·
In the first 24hs after using software update v2.9 I had to slam the brakes twice on that day or else I would have crashed into the car in front because of this chabge.
Just a quick note to say that since my OTA update to 2.9 there has been no change in OPD in my SRSM. Braking is still good with about 50mtrs from 40mph to stop. In fact it is good to know that this OPD function has stayed constant throughout my last year of OTA updates From 2.4 onwards.
Creep was used when I first transitioned from an Automatic XC90 to my PS2. I’ve discarded it and don’t use it anymore but it was a useful feature making me feel comfortable when taking my foot off the brake and having it move forward.
#44 ·
Same here, maybe it's only the other variants that have been affected? or maybe a small but loud crowd? ;)
I am still on the low settings from the winter, and never used creep.
This is the weirdest community I have ever been. As a community we have a chance to put the word out there to introduce improvements and make the car better
Maybe because this is a non issue for most of us, and very few people makes a big fuss out of it from analyzing the (maybe non existent) change to conspiracy theories.
#53 ·
I can't really speak to the standard setting since I prefer to use the brake pedal when coming to a stop. This is so I don't forget to use my brake pedal when driving my ICE car.
That scenario makes total sense when owning different types of vehicles, I am glad the low profile is accomplishing that as I truly think that is one of the intended uses for it.
#49 ·
Ok y’all, I’m still on 2.0 because of all these reported issues, and alleged changes. I don’t want my OPD to change. Make fun of me or look down on it if you want but my car works the way I want.
What I’m thinking though, is I still have the possibility to video these changes if it gets polestar to admit any mistake or change.
#58 ·
Ok so there’s a definite difference between 2.6 and now (2.9)… happened with 2.7 but can’t feel any difference 2.7 to 2.9….But it is still proper one pedal driving… some EVs you have regenerative but need the final touch on the brakes… I’m used to it now and still sharper than the wife’s IONIQ 5 set to the most aggressive of its 50 or so combo modes.. it’s fine and I think they changed it because it was too sensitive to even slightly moving your foot on the accelerator before.
#64 ·
I might be dating myself but is this any different than daily driving a corvette manual back in the day - getting used to the downshifting and then jumping in a BMW 2002tii which is a completely different car that has different gearing. You do adapt and get used to it. Yea the P2 OPD may have changed but is it so completely different that you can’t relearn the new pattern?
Also I did notice a softness after the 2.8 update but all it took was some aggressive driving full regen on and off the pedal and either it recalibrated or my brain figured it out but all was back to normal.
