221 - 240 of 288 Posts
244 / 5 000
I am very careful, removing the key without deactivating can completely corrupt the USB key!
PS: I stopped compiling roms and apps. Android and can't get over it to help verify the .apk!! in 15 years I lost my touch. I'm not 40 anymore 😁
Les fichiers comme le contenu sont-ils tronqués ? Ou les noms de fichiers tronqués ? Ce dernier serait tout à fait normal si vous l'avez formaté en FAT...
[/DEVIS]
Je ne suis pas anglais, difficile de détailler ! Les textes ne bougent pas, les fichiers non plus, c'est le son de certains MP3 qui sautent (comme une griffe dans un disque vinyle)
are the effected files permanently truncated? do they always skip in the car and pc or only in the car? is it always the same file(s)?
(est-ce que ce sont toujours les mêmes fichiers qui sont corrompus? dans la voiture aussi bien que sur pc? sont-ils endommagés de façon permanente?)
This can happen to any file and once damaged they must be replaced! Windows finds no errors there.
I have the same USB key in my other car and there are no problems (it's not an electric one but can read MP3).
Even a chkdsk of all the MP3 on the stick does not see the errors!
PS: My stick has 531 MP3 and 31 folders. When this happens it happens on a few random files, maybe 5-10 overall!!!
Have you tried a different manufacturers USB stick with the same files? (in their un-corrupted form obviously)
Hi,
I return again to my problem of damaged files on the USB key. Am I the only one having this problem? Not possible !
I have replaced the MP3s that are buggy, but it does not work, it starts again after a few days and a bit randomly with various files!!
Hi,
I can't replicate this issue myself. Is there something that the MP3 files that get corrupted have in common perhaps? Something like created with a particular piece of software, a particular bit rate, name/number in filename etc. When something appears to be random usually has a pattern as to why being the logic.
Discussion starter · #233 ·
I return again to my problem of damaged files on the USB key. [...] I have replaced the MP3s that are buggy, but it does not work, it starts again after a few days and a bit randomly with various files!!
Hi, I have released a new version of AudioWagon today, please try that one to see if it fixes your issue.
Unless you have turned automatic updates off in Google Play store, the app should automatically update to version 2.2.1. You can check the current version in the AudioWagon settings.
File damaged!! (File to download and listen with the Windows player)
Hi,
It's not as good as before! Always files that are buggy, no more 'eject' function
Hi Moleman,
Thanks for the update.
I installed it in the Volvo XC60 and can confirm artwork is now displayed when you select the Files tab section. Strangely the artwork does not display when you select the Tracks tab though which it did before but all is good. Thanks again.
Discussion starter · #239 · (Edited)
Artwork should only display in tracks, artists and albums tabs, never in files tab. (edit: should work in files as well)
