141 - 160 of 206 Posts
I'm lost in this same sea as you... getting my car in the fall and trying to get ahead of winter wheels/tires but finding few clear answers. Most shops have struggled to find something sufficient and online services basically tell me nothing matches. So finding reasonably priced winter wheels with the same staggered widths and offsets is essentially impossible here in Canada. And even finding the load rating seems harder than it should be.
I ended up finding a set of wheels that someone else on this forum had successfully mounted on the Performance Pack set-up, so at least I knew they would fit before ordering. I'd reco trying to see what people have already found on here and tracking down those wheels. Or make really good friends with a really good wheel shop and have them help you work through the trial and error. Good luck!
Thanks! Yeah I’ve actually since changed my order to a Performance because my original got delayed, and now I’m planning to just have high quality all-seasons swapped on from the start. I’ll either try selling the unused Continentals (probably on here since I think the size of them is relatively unique) or keeping them for spirited summer driving. Winters aren’t too bad around me luckily, so I realized I don’t necessarily need dedicated winters.
Anyone know if these will fit?
Found a set with 245/45/19 winter tires on them.
Bolt Pattern (PCD): 5x108
Offset (ET): 42
Center Bore (CB): 63.4
Finish: Matte Black
Lug Nut Seating: Conical
Weight(LBS): 29.6300928
Offset (ET): 42
Finish: Matte Black
Looks like a great find. I am not sure about the lug nut seating though. You should verify that your nuts are conical (instead of spherical).
Is anyone able to confirm that the OZ rally wheels fit on the P*2 PP? I know they put them on the Arctic Circle but you never know if they did anything custom to the car.
I've been researching that, too. I think (but don't know) that the 19"/8.5" rims with the 5 x 108 bolt pattern and 45 offset are the ones. Can't seem to verify though. I'm thinking of buying one just for a fitment check.
A lot of shops won't guarantee fitment because they don't have enough P2 info. I bought one Rotiform rim (19" x 8.5" 45 Offset) to test before I bought 4 (see my posts earlier in this thread). The Rotiforms I bought have tons of clearance on non-PP, but I have no idea if they would work on PP. I think you will have to buy to try. Just make sure to buy from a place that accepts returns if you don't mount a tire.
BBS XR’s fit the PP
Specs are 20x8.5 +40 offset. Love the way they show off the calipers vs. stock.
Like others who have have mounted similar width/offset combos, they protrude a bit more in the front.
Tires are Michelin X Ice 245/40/20 and boy, there is very little rim protection with this combo. Even worse than the OEM summers stretched on 9” rears.
For the fashionistas, center caps will be switched to black & gold.
Test fitted a wheel that fits the P2 with the Brembos. They are the Asanti black ABL-27 20x8.5 +38mm offset
Test fitted the wheels with tires today and this is how it looks. It does fit but I will have to caution that the wheel was designed with the valve stem inside the wheel barrel that will hit the Brembo calipers. They do sell flush mounted valve stem that uses an adapter for when you need to fill in air. This wheel does have another valve stem on the back side of the rim, so you can also fill up that way.
Here is the valve stem hitting the caliper. I now have flush mounted valve stems that clears without any issues.
Finally narrowed down my choices to these 2. I personally put the 1st one as my first option but the 2nd one feels more subtle. I'm buying them with winter tires but will swap them with my polestar 20" rims come summer. What do you all think? Should I go with 1 or 2?
Alutec Speedwheels GT6 8.5x20 ET45 (can get them staggered with 9x20 but I think I'll stick to the 8.5s)
Alutec Ikenu 8.5x20 ET45
