221 - 240 of 250 Posts
I’ve been struck with the TCAM monster for the first time in 8 months and 25k km since owning the car.
It started with the eCall service required message a few days ago but as of yesterday no more reaction on the physical keys and gps out. Luckely have PAK enabled which allows me to still use the car.
volvo dealer seems to be flooded so might give this method a go…
Worked like a charm.
Although my hand now looks like I’ve been playing with a kitten, but at least everything is back working, thanks for the clear write up!
the only thing is that the latest OTA still has an error after a failed install, was kinda hoping the reset would have fixed this.
On 2.4 and to my surprise, had the TCAM fail this morning. LTE then GPS out. Demister button nonresponsive. Pulling both batteries fixed it.
I've put approximately 5000 miles on it since I installed 2.4 and this is my first failure on 2.4, my fifth failure since I got the car. Besides forgetting to open the hatch before I pulled the 12V, I did the reset in about three minutes.
Keep those 10mm and long screwdrivers in the car.
Did you get 2.4 from the shop or OTA? I think the OTA 2.4 version is newer and is supposed to have a TCAM fix.
OTA. I was happily thinking that we are past this but it does seem to be less common. And I did not wait a day or two. I have trips starting tomorrow so need it to work (it was fun to unpack the hatch then repack!)
Update: P2.3 release notes suggested there were stability improvements relating to the physical keys:
However it was pulled soon after release ( September 2022). The next OTA is 2.5 (scheduled for December 2022) and has the same bullet point in the release notes so hopefully this time it won’t be revoked.
Even if it isn’t though it will be difficult to confirm though considering for some cars the first time the issue happened was over a year or in some cases nearly two years after purchase, so it’s best to be prepared.
There's an excellent post on how to properly disconnect both the 12V and the 3.6V TCAM backup battery, which you will need to do under certain circumstances to resolve certain issues (eg car fails to respond to physical keys).
Here it is:
A while ago I posted that the Volvo engineer that did this for me the first time my keys stopped working didn't bother to remove any trim, and neither did I when it happened again.
Unfortunately it happened once again and this time I took photos.
First of all, let me clarify when you will need to do this.
Others have reported this process resolved lack of LTE connectivity, lack of GPS fix and inability to adjust charge rate - I don't know about those, but if you tried everything else, it might be worth trying this too and see if it helps.
What I am certain this process fixes is what happens with my car. Every few months the TCAM gets into a state where it fails to recognise the physical keys. When this happens, touching the handle for keyless entry or pressing the buttons on the keys does nothing, however Phone as Key still works. Since PAK is still a beta feature I keep mine configured but disabled, so I can use it as a backup if I eg loose my keys, or this thing happens.
If this hasn't happened to you yet, I highly recommend that you:
  • Configure PAK even if you don't intend to use it, you may leave it disabled like I do as a backup
  • Always carry the large physical key with the key blade, at least when venturing far from home
  • Carry a wrench in the frunk (#10 for my car, others in the forum reported #11 which is weird, so check)
  • Optionally, carry a jumpstarter in the frunk (eg NOCO GB20/GB40 or equivalent)
Now if your car ever fails to unlock, the first thing you need to check is if the car is actually completely dead due to a discharged 12V battery. The easiest way to do that is to have a look at the red LED in the centre of the dash to check if it's blinking.
- If it's not blinking, your 12V is most likely dead and you need to jumpstart the car, which is easy, just follow the procedure in the manual. I hope you've got a jumpstarter in your frunk!
- If it's blinking then the 12V is just fine, so either your key's battery is dead (unlikely unless you had it for several years, but worth checking if you're at home and have the other key handy), or you have this particular issue with the TCAM.
Assuming you have this issue, then:
- if you have PAK setup and disabled, you can just activate it again. You should then be able to grab the handle to unlock and drive normally, but expect an "eCall service required" pop up and GPS fix loss soon. When it's convenient to do so (eg parked safely, ideally at home) you can spend the 5-10 minutes to fix this by following this process.
- If you don't have PAK configured, but have the key blade with you, you can use the key blade to open the door and you should be able to silence the alarm and drive the car by placing the key in the transponder in the cup holder under the armrest and selecting drive or reverse while depressing the brake pedal as usual. If this doesn't work remove any additional cases/protection etc the key might have and try both sides, if it still doesn't work consider removing the cupholder insert and placing it as far back as possible (see here).
- If you don't have PAK configured and also don't have the key blade with you, then there's not much you or even roadside assistance can do until someone brings the physical key over (which is why I recommend always carrying it with you, when planning to drive far from home).
Anyway back to the process, assuming you've used PAK to unlock the car and you just want to fix the issue so your keys work again.
First you need to disconnect the 12V battery.
To prepare for this:
  • make sure the car is not plugged in
  • pop up the frunk and the rear hatch so it's open before you disconnect the battery
  • close all doors
  • wait for the car to go to sleep (the charge port LED is a useful indicator, wait until it turns off)
When you're ready, follow these steps:
Step 1: Push the centre of these two fasteners in, so you can pull them out. Try not to loose them in the bowels of the engine bay as I often do:
Step 2: Don't bother doing the other side, and just raise the flimsy plastic up to reveal the 12V battery, or at least the half that has the negative pole, which is all you need:
Step 3: Use your wrench to untighten the nut that secures the connector to the battery's pole until you can pull it out and leave it to the side:
Now go and check the car is really dead, because if the DC-DC converter was active at the time (unlikely, but it happened to me once), disconnecting the 12V will do nothing other than give you a warning there's a fault with the 12V charging system. Ignore that, the fault is you just disconnected the battery, so connect it again and give it a few minutes before attempting to disconnect it again.
The simplest thing is to keep an eye on the charge port LED and wait for it to turn off, but if you have a multimeter handy you could monitor voltage and wait for it to drop from >13V to <13V.
If you've made it and the car is completely dead, it's now time to disconnect the TCAM battery.
Step 1: Go back to the boot/trunk (whatever it's called in your continent), and just grab the carpet like trim on the left hand side and pull it:
Step 2: There's nothing to break really, it's mostly metal clips clipping on gaps on the bodywork. You'll find the battery tucked underneath the C pillar, you might attempt to disconnect it in place, but I find it easier to just unclip it and remove it to do it: Here's a photo after I unclipped it:
Here's a photo of the battery:
Here's one from the side to see how it clips on the car, the left hand side of the photo is towards the rear of the car, and that's the bit you need to push if you want to remove it from the car.
If both have been disconnected for a few seconds at the same time then you're done, just reconnect both and check that your keys work again. If they do, great, put everything back the way it was and hopefully it won’t happen again for a few months!
If you are having trouble pushing the battery tab from bellow try this approach instead:
As this might happen again you might want to remount the backup battery to a more accessible location:
Update: @mxs found this video that might help:
It's a little sad that Polestar owners have to resort to this procedure to fix their connectivity issues. Polestar need to come up with a permanent solution and do a proper recall. Nowadays they are so busy with releasing new vehicles but let this very serious issue tarnish their brand. I assume this issue gets carried over to every new model they sell. The more vehicles they sell, the louder the complaints get. One of the owners may bring a class-action lawsuit at some point. Is this what Polestar wants?
Did your keys also fail? I'm on 2.4 as well and have had LTE go out a few times, it has always come back on its own however, latest on the next drive.
Discussion starter · #231 ·
Coincidentally I was thinking yesterday that it’s been months since we’ve heard of someone having this issue so it might have been fixed after all :/
Did your keys work btw?
I use the full size key fob, and had no problems locking the car or getting back in. The LTE and GPS were down for about three hours, and for one of those hours the car was parked and I was away from it. Although previously the demister reset has been working on 2.4 for me, this time it did not work at all as a reset, even when I held it for >60 seconds. As I am experienced in doing the reset and its a busy week for me, I did not let it sit overnight to see whether it would fix itself, which it may have done. 2.5/2.5.1 also may have fixes in them. That all being said, GPS and LTE were instantly back on once the battery reset was completed.
Volvo has been plagued with TCAM failures too of course, yet a quick peek at the Swedespeed site isn't showing much activity lately regarding TCAM failures. Even so, as the failures are a safety concern if the driver is depending upon the connectivity in an emergency, if there should be a recall of some sorts then yesterday's news should have some indirect pressure to address it (Volvo Group is the truck/bus entity, so it is quite indirect but still related): U.S. hits Volvo Group North America with $130 mln penalty over delayed recalls
I'm at the shop on February 10 to get the kick sensor installed and address a couple other things. Will chat to the techs there, who are well versed with the reset procedure (we compared TCAM fix kits last time) and they will of course know how often they are still seeing cars with this issue. I'll also send in the screenshots of the failure to customer service for the record. Obviously from the activity here it is much less common if not eradicated, but at the same time, if it still can happen it is a concern.
It's not like your brakes or airbag are failing, so this is hardly a safety concern. Maybe it's a first world safety concern. But many of us have driven hundreds of thousands of miles without GPS or LTE signals ;)
From what I've gathered, this is not something easily recalled because the causes are disparate and unique. If there was a singular fix, they likely would have issued a TSB (not recall) and been done with it.
Of course agree. Yet if you bought the car with certain safety features and they had failed to activate that’d be of concern to those with itchy legal pens.
My first car was a ‘66 Mustang with lap belts and no headrests. I was concerned with connectivity of a different sort when cruising around.
I see this feature as something that makes you feel safer, but is not a specific safety feature. More of a convenience feature. If your cell phone fails, you can't sue Apple/ATT because you are less safe.
Well, technically both the “Emergency assistance with Polestar Connect” and “Automatic Crash Notification” would be considered safety features right? Especially the latter.
Replying just for a “point of reference” — details as follows:
This is my second P*2 and my wife has 30k miles on a 2021 Volvo XC40 P8 Recharge. In her volvo, the reset of the infotainment and/or TCAM by defrost button has ALWAYS worked. Never in 30k miles/2 years have we been w/o TCAM as that has always worked. My first P*2 was short lived, so no TCAM data points.
This car has 4,300~ miles, is 90 days old — 2023 Polestar 2 LRDM. Updated to v2.7 a few weeks ago, and The car has been flawless in the connectivity. No TCAM issues to date— so 3+ months just fine, updated v2.7 just fine, etc. Then 2 days ago, no LTE. Tried resetting infotainment, no dice. Tried defrost button method, no help. Tried unplugging TCAM battery while unplugging a few of the fuses, that didn’t work either.
Tonight after work I did the method here — the “easy” way without removing panels just peeling back (I’ve got really small hands/arms so that made the job easy). Ten minutes unplugged (12V battery/TCAM battery). And worked like a charm! LTE has been restored! Again just sharing my findings in case anyone else on v2.7 with a ‘23 wants to give this a shot. I realize the findings have been irregular for what works for which cars when; but data is data, so why not share, right? :)
Good point - if you're at home or carry one in the car then yeah that'd guarantee you get it right first time, but to be honest in most cases closing the doors and waiting a minute does the trick. I use the charge port LED as an indication the car is asleep, it'll turn off when it does, so that's a good time to disconnect the battery.
I'll update the post again.
BTW I was thinking pulling out fuse 26 under the glovebox instead of disconnecting the 12V battery should do the trick, but frankly it's so annoyingly placed that I decided disconnecting 12V was easier.
Something I might try next time this happens, as for some it might be easier to do this and it means you don't need the wrench.
What am I doing wrong? The green light on my charge port stays lit!
Bonnet & boot open, doors closed but unlocked, green light remains. Same if I lock the doors.
Ok- after 30 mins the charge port lights went off. Took me longer than 5 minutes to locate & detatch the 12v battery, my arms look like I tried to get too friendly with a feral cat but I have connectivity once more. Thanks @kkonstan et al
Discussion starter · #240 ·
It’s been a while since this thread had a post, I was hoping nobody else would need to do that, glad it worked in the end.
Which issue did you do this for? Key buttons not working or something else?
